ECM label
1 Attachment(s)
My 93 Ruby is missing the ECM label. I took a picture of my 92Z's label and this is what it looks like. Anybody have a 93 ECM label picture to compare? The other ZR-1's have different info on them. The NCRS manual calls for service part #16163993 to be on the label.
Re: ECM label
1 Attachment(s)
This is from a 94 ZR-1 ECM.
Re: ECM label
Here is "WeGone" from his '93 in this link: http://forums.corvetteforum.com/1586825229-post7.html |
Re: ECM label
Thanks! It seems that there are all sorts of different labels.
Re: ECM label
http://zr1.net/forum/showpost.php?p=201741&postcount=5 I would think I would want to confirm with builds before the production dates shown in the chart and those after. I don't have any idea of "WeGone" build date and how it compares with the chart I posted. Important? You could have the NCRS guys scratching their heads if you quizzed them. BAZJ or BFDM |
Re: ECM label
Interesting. Marc thought that the BKRR was from late 93 to mid 95 but your chart shows me that the BC could be any of 5 different ones. My car build date was April of 93. Don't know if that plays into it but it narrows it down. My question then would be this: Did Merc Marine do this at their factory since they built the engine? How far in advance did they do this? I would hazard a guess and say that it would be BFDM only because of the dates involved. The NCRS manual states that it would to be 16163993 but there are 4 different BC's. Other than pulling the chip out, is there any other way to find out what it is supposed to be. I was told by the owner that he updated the chip. My 92 Z is #423 built in May of 92 but the BC was built in Nov of 91.
Re: ECM label
The ECM install would have been an assembly line install. #371 in '95 is a BMCB |
Re: ECM label
Actually, it's box 56 and it says BFDM. Found out from Gordon that the ECM was put on at the plant and the Delco/Delphi people put it together and ship them to the plant. Now to see if there is a placard that can say that. Thanks for the help! You are very much correct about the assembly line install.
Re: ECM label
