Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > Cleaning and Waxing
Old 09-18-2017   #1
conesare2seconds
Default Underhood and suspension cleanup
Hi everyone. 1994 124 was a Texas car and lived in a dusty environment. Once it was back up to spec mechanically it was time to give her a good bath.
There were two complications: First, the dust had some clay content and turned to a sticky paste when wet. Second, a "pro" detailer gave the inner fenders and wheel liners a coat of aerosol plasti-dip. The rubber coating encapsulated the dust and had to be removed with acetone, followed by cleaning the dirt itself.
Detailing tools were a spray bottle of distilled water, a spray bottle of Super Clean degreaser diluted 4:1, acetone, soft body and wheel brushes, a boar's-bristle brush, assorted small plastic and wire bristle brushes, microfiber cloths, and a Scotchbrite pad.
Old 09-18-2017   #2
conesare2seconds
Default Re: Underhood and suspension cleanup
Our engine is showing its age and miles. It will never be truly beautiful again short of a refinish but its appearance can be improved. I used a mild polishing compound to remove surface contaminants and tried toothpaste and an Adams product as recommended here, but I wasn't able to clean deep stains.
In the pic below, the rear runners and cam cover directly beneath have been cleaned.
Old 09-18-2017   #3
conesare2seconds
Here's a look at the rubber spray coating after a couple of thousand miles to Bowling Green for the Gathering.
Old 09-18-2017   #4
conesare2seconds
Progress. Clean side on the right, dirty side on the left.
Old 09-18-2017   #5
conesare2seconds
A closer before view of the inner fender and steering knuckle area.
Old 09-18-2017   #6
conesare2seconds
This is more like it.
Old 09-18-2017   #7
conesare2seconds
The engine area is looking much better in these after pics.
Old 09-18-2017   #8
conesare2seconds
Here's the starting point for our rear suspension. Nasty.
Old 09-18-2017   #9
conesare2seconds
Finished this side after dark and had to put a shop light on the subject to get a pic.
Old 09-18-2017   #10
conesare2seconds
Here's the finished DS.
