Go Back   ZR-1 Net Registry Forums > Racing > Personal Racing Stories
Old 03-07-2013   #1
aafc
aafc's Avatar
Default a little test and tune at orlando speeworld
March 6, 2013 Orlando Speed World was open for test and tune runs.
temp was about 68 deg. with little wind and low D.A.
Car : my 1990 ZR-1 with 4l80E auto and 3.73 rear gears.
1st pass left @ 1200 rpm 2nd and 3rd passes left @ 1800 rpm. each pass
trans shifted @ 7000.
my 1st pass @ 6:50 p.m. 2nd pass @ 7.31 last pass @ 8:48
R/T .371 R/T .776 R/T .581
60' 1.719 60' 1.698 60' 1.722
330' 4.917 330' 4.865 330' 4.888
1/8 7.525 1/8 7.452 1/8 7.473
MPH 92.26 MPH 95.03 MPH 95.10
1000' 9.787 1000' 9.698 1000' 9.716
1/4 11.687 1/4 11.585 1/4 11.600
MPH 118.49 MPH 118.80 MPH 119.38
As you see i need to work on my reaction times, but the runs were great
plus track traction was very good. as my 60 ft times last year were
1.74 to 1.78.
After racing as i put the " Z " back in the garage the mileage just turned
over to 121,000 miles. When the weather gets warmer here i think my e.t.'s
will drop to 11.75 or slower.
Thanks for reading
John Becker
1990 white/black # 2546
one of a few auto ( 4l80E ) eq. ZR-1's
Old 03-08-2013   #2
mgg
Default Re: a little test and tune at orlando speeworld
Whats been done to the motor? Nice 60 ft. It seems that the auot works pretty well. I would have guessed with the absence of low end on thee motors the 60 ft. might not be as good with the auto. Thanks for posting. Some impressive times. Just curious as to what modes other than the trans and the gears to generate those times and mph.
mgg is offline   Reply With Quote
Old 03-08-2013   #3
aafc
aafc's Avatar
Thanks,
The motor was rebuilt by SGC, its his 550 hp pkg. 368 cu in with stage 1
cams. On a Dyno, after adjusting new injectors it pulled 418 RWHP. do not
remember what the RWTQ numbers were. Tires are BFG drag radial at
26 lbs. Now i have to tell you that the DA was - 60' ft plus dry and no wind
or dew. Some one said it was a mine shaft air.
1990 white/black #2546
one of a few auto ( 4l80E ) eq ZR-1"s
Old 03-08-2013   #4
Hog
What torque converter are you using in the 80e? What is the flash stall when you launch?
Nice times.
peace
Hog
Old 03-08-2013   #5
aafc
aafc's Avatar
Hog,
I'am using a 3200 stall converter made by FTI in Deland FL. I leave the line at
1800. The trans is controlled using comupshift, I have it sent to shift at
7000 at WOT. After burn out I shift into 3rd gear ,stage, come up to 1800
last yellow bury the pedal and keep her straight. Then hang on and enjoy the
ride. I may try leaving at a higher rpm ( 2000-2200 ) if i can hold on foot brake.
one of a few auto ( 4l80E ) eq ZR-1's
Old 04-10-2013   #6
boostedmaxPSI
Nice numbers. Thanks for sharing.
1966 Mustang GT tribute
1988 Callaway Twin Turbo Aerobody (FOR SALE pm me for more info)
1991 Callaway CR1 SuperNatural 475 Aerobody
1992 Callaway SuperNatural 435 Aerobody (sold)
For Sale:
boostedmaxPSI is offline   Reply With Quote
Old 04-29-2013   #7
aafc
aafc's Avatar
Default Re: a little test and tune at orlando speeworld part 2
April 27 2013,
Points race 1/8 mile.1st time run RT -.133 60' 1.752 1/8 mile 7.561@ 93.92
2nd Run RT -.070 60' 1.741 1/8 mile 7.562 @ 93.91
For 1st round dialed in at 7.55.
Ran 60' 1.713 1/8 mile 7.521 @ 93.90 O yeah red lite again, but i had a
blast.
