01-30-2015 | #1 |
Anybody got a wiring harness they can cut up?Im
I'm looking for the two plugs and the relay for the antenna for a 91. Not looking for the entire harness,Thanks.
01-30-2015 | #2 |
Re: Anybody got a wiring harness they can cut up?Im
you want them off of the main harness?
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
01-30-2015 | #3 |
I believe these are on the main harness under the rear window trim.
01-30-2015 | #4 |
Okay..
How much wiring pigtail are you looking for? How much are you looking to spend? I have a harness, I will not part with the harness, but might consider selling the plugs you need
01-30-2015 | #5 |
Maybe 6 inches. I have no idea what this is worth,throw something out there.
01-30-2015 | #6 |
Let me find it.. I have it stored.. give me a few days
01-31-2015 | #7 |
If you search for Weatherpak connectors, you should be able to find the plugs themselves and transfer wiring over to them. Unless you are saying somebody cut the wiring.
02-08-2015 | #8 |
do you have pictures of the connectors you are after? I found my harnesses.. but I want to verify what you are looking for
02-08-2015 | #9 |
The plugs I need aren't Weather pack but are a 3 cavity connector. I've been in touch with Terminal Supply which has all of the OEM connectors and they can't identify the plugs. I'm talking to somebody parting out a 90 so I should find what I'm looking for.
