Old 08-31-2011   #1
Nacho_ZR1
Default Raptor shift light - what RPM should I set this to?
Going to a buddies this evening to get this thing installed. What is a good RPM to set this to..7k?
[B][U]---SOLD BUT NOT FORGOTTEN---[/U][/B]
[SIZE="1"][SIZE="2"]1992 ZR-1 #483
[COLOR="DarkRed"]Dark Red Metallic[/COLOR]
[U][B]Mods[/B][/U]
-Jeal headers
-Stock exhaust with X-pipe
-4.30 Gears
-Corey Henderson tune
-375 RWHP[/SIZE][/SIZE]
Nacho_ZR1 is offline   Reply With Quote
Old 08-31-2011   #2
Default Re: Raptor shift light - what RPM should I set this to?
That depends on your age (I.e. reflexes!) A "good" Z brother friend said I should set mine at 5500... (Ah, the FBI Brotherhood can be brutal!)
I have a Fidanza and set mine at 6900, & in first gear the 7200 rev limiter comes mighty quick! Higher gears and I have a few milliseconds to react- not so quick. In third there are a few more milliseconds to react.
It is a learned thing. It takes some getting used to, whereever you set it. And, what mods you have (mine being a "500" package adds 2-3 hundred to what works with stock. The track is the ultimate test, of course!
And, just in case that schmartazz FBI friend is reading this, I'll have him know I bought mine used and I found it set at 6700...So there!
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 08-31-2011   #3
6500-6700
