Old 09-12-2011   #1
SteelBlueZR1
Question Brass vs. Plastic Headlight Motor Gears?
My 1991 ZR1 with 4k miles p/s headlight is doing the wink thing and running after turned off... so it is time for new gears/bushings.
When replacing gears and bushings in headlight motor, what are the + and -'s of plastic vs. brass gears. What kit do you recommend for the 1991 ZR1, so this will be a lifetime fix?
Bert Rankin
1991 ZR1 Steel Blue / Steel Blue
#1029
Haibeck chip, slotted rotors, camber brace, C-beam plates, OBX exhaust, Nitto NT555 tires
[SIGPIC][/SIGPIC]
SteelBlueZR1 is offline   Reply With Quote
Old 09-12-2011   #2
rhipsher
rhipsher's Avatar
Default Re: Brass vs. Plastic Headlight Motor Gears?
If its making the Ca Clunk Ca Clunk Ca Clunk Ca Clunk noise then its most likely that you just have to replace the 3 9/16 dia x .425 long plastic pieces that have crubled that sit inside th gear. You can pic them up at any auto parts store in the window regulator section for $9.00 a set. You should'nt have to replace the gears. But Id go with brass if I ever had to replace the gears.
Old 09-12-2011   #3
Tried a local auto parts and they hadnt a clue...
Any place you recommend and or a part number for the plastic bushings?
Thanks
Old 09-12-2011   #4
VetteMed
I've been told that you can buy em in home depot/lowe's in the hardware aisle... never looked, I just bought mine on ebay for a few bucks.
2004 Z06/Z16 LeMans Commemorative Edition
1991 ZR-1 #302 White/Gray (sold)
1991 ZR-1 #1147 Red/Saddle (sold)
Old 09-12-2011   #5
rhipsher
rhipsher's Avatar
Thanks
They are not going to know anything about it. Just go into Orielly's and walk back to the window regulator section and you will see them either in packs of three or two. They are 9/16 diameter round X about .425 long.
Old 09-12-2011   #6
gbrtng
gbrtng's Avatar
Any parts store with the HELP stuff has them. They come 3 pieces to a blister pack for about $7.00 - seem to remember they are called a part of a Ford pickup window regulator.
Solid white nylon rod like Mid America sells.
Old 09-12-2011   #7
Brass/Bronze is a life time choice for your 91 ZR-1. The failure point is the Delran bushings. Available at Madvet or Ecklers. If you buy the brass gears the 3 bushings normally come with each gear in a kit. Also as stated the HELP section has the same bushings. GC
Old 09-12-2011   #8
USAFPILOT
USAFPILOT's Avatar
I bought the brass gear set wit the solid plastic bushings. They are hard as hell to press into the brass gear, but I got them in and am having no trouble. I have no idea how long they will last, time will tell. Brass is still a soft metal, so if it starts to slip I think it will grind down. The best bet is to change those plastic bushings at the first sign of wear. So if you ever hear it clicking before it becomes a one eye, change them.
Old 07-02-2013   #9
Schrade
Article in vette magazine said go with plastic gears, not bronze.
You want the plastic gears to fail, instead of the motor. Article also said weight of bronze gear is a factor. I don't know better to argue with their experience...
Tags
brass, gear, headlight, plastic, repair
