04-25-2019 | #1 |
Car is running Fantastic
Brought the car out from storage and it has been running great.
I just got done doing the following: - Updated/Wasinger Fuel Regulator - New Spark Plugs 41-801 this time - Replaced coils - New Custom Ignition Module Need to change oil and swap the fuel filter along with doing an alternator upgrade with associated wiring and I will be all set
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
04-25-2019 | #2 |
Re: Car is running Fantastic
Good to hear Jeff. I'm running strong also. Still getting use to the yellow. I am going to do a dyno run soon to see what this combo does.
I also got my orange taillights to swap into the euro taillights look.
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* |
04-25-2019 | #3 |
Nice, I don't expect to reschedule again.. life has been quite busy here
04-25-2019 | #4 |
Jeff,
What are u meaning about a “custom ignition module”? Have u modified the stock ICM? Inquiring minds want to know. What ignition coils are u using?
04-26-2019 | #5 | |
The Stock harness is not cut, I ran a new wire to the crank sensor and just found a mate connector so will change to that and remove the added wiring. I repinned one wire @ the ECM and ran it to the empty spot on the diagnostic connector. the new module then plugs into the diagnostic connector. I truly think the car runs better overall, seems much smoother. the new module is not high power, it jut is a controller for the LS Coils so it takes a very low amount of current 300mA max I believe the only downside is the unit needs to get installed in the cabin as the components are not all the higher temp ( Military spec), most or Industrial
04-26-2019 | #6 |
WOW! That sounds like exactly the kind of solution our cars could use. I like the idea of using the LS type coils and having one coil per cylinder even if it runs “waste spark”. I would think it may have benefit in the higher rpm range in particular.
04-26-2019 | #7 |
Nice work, Jeff. I applaud this effort. Does the tacho work? What about the serial RPM stream? All of that is produced, I think, by the factory module.
Todd ____________________________________ *** our email address has changed! info@pepmeierengines.com pepmeierengines.com Friend us on Facebook too: www.facebook.com/profile.php?id=100011443683384 Pepmeier Engine Development |
04-26-2019 | #8 | |
I assume you mean RPM stream to the ECM? it wires to the ECM just like the Stock IM. The repinned ECM wire is the fault line, I now have it running to the diagnostic connector in the empty location and then that is the connector I run to the new IM. the Fault line was the only one missing from the DIAG Connector I never could find the mate to the long flat IM Connector, I just found a mate to the Crank Sensor plug that went to the stock IM, so I can switch back to the stock wiring for the crank, by do that it makes it even more plug and play.. I did not cut the Fault line at the ECM, removed it and taped it back and ran a new wire.
04-26-2019 | #9 |
This is the IM mounted, I orderd the mounting brackets and they sent blue instead of silver, but they still work to mount it..lol. Earlier picture of testing below IMG_0032.JPG Needed to confirm it worked before going through the effort of mounting everything. IM is the silver box on top of the ECM Picture of coils IMG_0056.JPG IMG_0057.JPG Sent from my iPhone using ZR-1 Net Registry
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 Last edited by -=Jeff=-; 04-26-2019 at 04:06 PM. |
04-27-2019 | #10 |
Love it when a plan comes together. Thanks Jeff. A fascinating alternative, and actually a better one than the stock ICM.
