11-26-2015 | #1 |
Clutch recommendations
So, I replaced my clutch, flywheel, pressure plate and throw out bearing with an aftermarket. Big mistake.
Do I go back to stock? I've got a Fidanza, which was the start of it all. So, I'll install the Fidanza, but what to use for pressure plate and throw out. I liked the idea of the hydraulic release to get away from the fork and ball, but that didn't work out. |
11-26-2015 | #2 |
Re: Clutch recommendations
Don't know what's going on but here is one of my LL
Ted http://www.zr1.net/forum/showthread....ghlight=Clutch |
11-26-2015 | #3 |
I just replaced mine last week with all OEM, why not go that route?
[CENTER][SIZE=4][COLOR=red]1990 ZR-1 Red / Red[/COLOR][/SIZE][/CENTER] |
11-26-2015 | #4 |
If you're using the Fidanza, go w new throw out and pilot bearings. I use the Camaro LT1 sprung hub disc and stock pressure plate.
11-27-2015 | #5 |
I have the Fidanza and stock PP and the Camaro sprung hub disc (Centerforce fm Summit #381039). Love it!
Also, (it's been a while now) I installed longer (custom) bolts that were part of a kit that included the drill bit and tap, as I recall. (Maybe Dom remembers or has the info on the bolts - I (alas) have lost track of the particulars...) If and when I need a new clutch, I'm going with the RAM dual-disc setup and be done with clutches thereafter! (I'm assuming their clutch will work with the Fidanza, but maybe not.)
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 11-27-2015 at 06:31 AM. |
11-27-2015 | #6 |
11-27-2015 | #7 | |
My Z has the "500+" package w/ stock cams. The idle was bumped to 850 rpm to assist with noise. Basically, there is none - or at least nothing worth mentioning. (Now Ami's Z is cammed. That is a different story - but like I said...her's is also cammed.) My Z at idle with the Fidanza/sprung hub disc/stock PP: https://www.youtube.com/watch?v=y1YFa8ruh8A
11-27-2015 | #8 |
Good article on Marc Haibeck's website.
http://www.zr1specialist.com/HAT%20W...el-clutch.html Marc believes the PP is good for 550chp. I have had good reliable experience w my setup which approaches that level of power. With the Fidanza you'll want ARP bolts that are the correct length. I believe both Marc and Jerry's Gaskets have them. With judicious tuning, and good trans lubricant the idle rattle is minimized at idle. There is no rattle once clutch is engaged. I just switched to Amsoil Manual Trans fluid since the Castrol is no longer available through BMW centers. So far I have found the Amsoil to work just fine maybe even a bit better than the Castrol in controlling idle rattle with higher fluid temps. Shifting smoothness hasn't noticeably changed. I have a Hurst short throw.
11-27-2015 | #9 | |
11-27-2015 | #10 | |
I believe Jerry"s Gaskets is carrying the kits too. So, something isn't making sense...!
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 11-27-2015 at 01:24 PM. |
