Old 04-10-2019   #1
Norwegianmopar
Norwegianmopar's Avatar
Default LT5 rev limit
What is the norm when it comes to the rev limiter on people's ZR-1's? I have been up towards 8000 rpms and never had any cut-off of any kind...Is this normal?
Roy Martin
1994 ZR-1 #112 Admiral Blue/Black
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
1991 ZR-1 #400 White/Red (SOLD)
Dana 4:10
Powder coated engine
Haibeck performance chip
Borla exhaust
Norwegianmopar is offline   Reply With Quote
Old 04-10-2019   #2
Top Toy
Top Toy's Avatar
Default Re: LT5 rev limit
No. Someone apparently eliminated the rev limit from your chip. Stock cut off is a little over 7000. You can safely push it a few hundred higher.
Sent from my HTC U11 using ZR-1 Net Registry mobile app
'95 ZR-1, aqua/gray, #167
Old 04-10-2019   #3
The stock cutoff is approx. 7100, unless like mine it has been boosted to accommodate the extended power curve (resulting from porting and cam phasing).
But, it could be your tach is reading high - which is quite common as result of deterioration of the resistor voltage divider board on the instrument cluster. For example, before I recalibrated it the tach read 8000+ when in fact actual rpm was 7000 rpm.
There is a procedure to recalibrating the tach, i.e., determining the proper resistance and replacing the stock resistor board with the correct resistors replacing the stock board. However, BATEE now provides new resistor board replacements, so now a simple board swap is all it takes to recalibrate the tach.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 04-10-2019   #4
Ccmano
Ccmano's Avatar
Www.Batee.com has what you need if the tach is reading wrong. And yes quite common.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 04-10-2019   #5
EvanZR1
EvanZR1's Avatar
Probably your tach being way off in your dash cluster. Before sending mine off to Batee, I could literally pin the tach needle without hitting the limiter. Was probably off over 2,000rpm.
Evan
2023 70th C8 HTC, 94 Admiral Blue ZR-1
SOLD - 2012 Carlisle Blue Metallic ZR1 - 800HP
SOLD - Steel Blue 91 391cid ZR-1 #391
SOLD - Black 91 ZR-1
Old 04-10-2019   #6
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Absolutely, and very common!! ( same as the previous two said as well )
And Batee is THE place!
Marty
