Old 11-21-2014   #1
Hib Halverson
Default Brighter Aftermarket Headlamps
We all know the stock headlamps in ZR-1s–all C4s for that matter–majorly suck. If that bothers you and you want to do something about it, I have two sets of aftermarket, quartz-halogen headlamps for sale.
Both use H4-type, "high/low beam," quartz-halogen bulbs. Both sets have metal reflectors and glass lenses.
One set are E1-coded lamps made by Hella in Germany and have 80/55-watt bulbs.
The other set are E2-coded lamps made by the French company, Cibie and have 130/100-watt bulbs
Both sets come with light bulb dust boots.
Both sets are bolt-ins, that is: you take out your stock glass or plastic, sealed-beams and put in the aftermarket lamps. You may need to re-aim the headlamps to your satisfaction.
Either of these aftermarket headlamp sets will give you better lighting during night driving.
40-bucks plus shipping for the Hellas.
50-bucks plus shipping for the Cibies.
Email me at fin speed@netmotive.net if you are interested.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 11-21-2014   #2
gbrtng
gbrtng's Avatar
Default Re: Brighter Aftermarket Headlamps
I'll take the Hellas. email to follow.
Glenn
Old 11-21-2014   #3
Hib Halverson
SOLD!
Glenn got the Hellas.
The Cibies are still for sale...50 bucks plus shipping.
Hib Halverson
Technical Writer
Old 11-21-2014   #4
nelson007
nelson007's Avatar
I will take the other set.
Have emailed you
Nelson007
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
2012 ZR1 Preproduction
nelson007 is offline   Reply With Quote
Old 11-21-2014   #5
Jagdpanzer
Jagdpanzer's Avatar
Hib,
What headlamps are you running now?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 11-24-2014   #6
Hib Halverson
Have emailed you
Nelson007
SOLD!
Nelson gets the Cibies
Hib Halverson
Technical Writer
Old 11-24-2014   #7
ghlkal
ghlkal's Avatar
Hib,
I'd like to know too
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 11-24-2014   #8
When I first got WARP TEN and had Marc do a lot of maintenance and improvement items, we discovered that one of my headlights was cracked. So he replaced the old stock H2 65/60 watt OEM headlights with Hella H4 85/80 watt off-road units. Also re-aimed the lights. Definitely improved visibility and not a problem for oncoming drivers despite the off-road designation.--Bob
Old 11-26-2014   #9
batchman
I put a set of Cibie H4's on my full-size Bronco and it was almost the best mod I did to that truck. They were flat freaking amazing, and the cut-off for low beams was perfect. I liked them so much I moved them to my new (same era) f350.
You guys are going to like these, but I'm a cautious guy so I made sure to put them on high for 10 minutes then check the wiring temp. Come to think of it I didn't do that on the new truck - yet.
Cheers,
- Jeff
Old 11-27-2014   #10
gbrtng
gbrtng's Avatar
Instead of watching the wiring temperature, I check the current draw with an EXTECH MA220 clip-on DC ammeter. (The handiest tool for tracing electrical gremlins too.) Knowing the wire size, I know the maximum safe current the wire can handle.
QED
