05-15-2014 | #1 |
Bose help needed
I just bought a 91 ZR-1 and the Bose radio has no sound but the tuner works. When I got the car the battery was dead. Could the radio be coded? I don't have any manuals for the car and I can't remember if they say "Code" on the display or not.
What is an easy way to trouble shoot the system? Thanks, Jon |
05-15-2014 | #2 | |
Re: Bose help needed
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 05-15-2014 at 09:54 PM. |
05-27-2014 | #3 | |
Thanks for your help! |
05-27-2014 | #4 | |
This is what you are looking for. You will need the white connector on a pigtail also. You should be able to get these amps for $5-$7 at pull your parts wrecking yards.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 05-27-2014 at 07:09 PM. |
05-27-2014 | #5 | |
They had a GXE and a SE model. If it is with the base radio that will help me when I call the salvage yards to see if I can find some. Thanks again. |
05-28-2014 | #6 | |
I just looked at a 98 Maxima and it had Panasonic rear speakers with the factory radio so I am confused. I will keep looking. |
05-28-2014 | #7 | |
The 95' Nissan Maxima Speaker with Amps look like this..... The 95' Nissan Maxima Amps are direct replacements for Bose Amps in the ZR-1. The only issue is the little white connector on the Nissan Amps is much more usable than the original soldered connection (1990 ZR-1s) on Bose Amps. Pigtails for Nissan Amps are available. 95' Nissan Maxima Front Speakers..................................95' Nissan Maxima Rear Speakers See Bose Speaker Amp Options TIPS
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-02-2014 at 01:23 PM. |
06-01-2014 | #8 |
1996 Maxima also. Just picked up 4 today. Thanks for the help on the solutions page.
'95 ZR-1 RED/GRAY #261 '95 ZR-1 BLK/BLK #268 '89 6-Spd FX-3,Z51 BLK/BLK |
06-01-2014 | #9 | |
thanks |
06-01-2014 | #10 |
