09-16-2013 | #61 |
The OPRV Cover Plate Oil Leak looks like front of oil pan
The OPRV Cover Plate Oil Leak looks like front of oil pan leak and is hard to diagnose.
OPRV (Oil Pressure Regulating Valve cover plate )......It will appear that the oil pan front bolts are loose and leaking at gasket. Potential Oil Leaks and the OPRV Cover Plate
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-16-2013 at 06:20 PM. |
10-02-2013 | #62 |
Re: engine wear
I finally got around to putting pan gasket #2 on this beast. Had a helping hand this time too which was nice. Got her out for about 10 miles yesterday then today really put it through her paces. Oil pressure was good, everything was good and after today's drive for about 40 miles the permagrin is back on my face and the under side of the car is completely dry. So now I'll have about another month or so I can drive her before the winter weather rolls in and then I'll get to that crankcase pressure issue and check my pcv.
10-02-2013 | #63 |
Re: engine wear
Good for you
Check the oil pan bolts once in a while just in case Last edited by Dynomite; 10-03-2013 at 07:17 AM. |
10-02-2013 | #64 |
Re: engine wear
pittsburgh cars and coffee is saturday if you want to put some shake down miles on her
10-03-2013 | #65 | |
Re: engine wear
Make sure to get out and inspect her after she's sat for a bit. In the unlikely event that the leak is not quite completely gone, spotting it on a nice clean engine is easier. I've got a really really really tiny leak coming from what was apparently a tiny rock hitting the small oil cooler at the bottom of the radiator stack. In my case it was easy to spot when all was clean.
Scott Vett owner since 1979._It's about the car and the people Last edited by scottfab; 10-03-2013 at 10:24 AM. |
10-03-2013 | #66 |
Re: engine wear
Nice clean engine Scott, I wish mine looked that good. One of these days!
Joe |
10-03-2013 | #67 | |
Re: engine wear
Still people that see the engine stop and stair for a bit. It's a work of art even 24yrs after it's birth
10-04-2013 | #68 |
Re: engine wear
Concur....there is nothing wrong with alterations
At All Dynomite's 1991 LT5 Dynomite's 1990 LT5 Concur Also......there is nothing wrong with Colored Bold Text........it helps identify Key Features
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-04-2013 at 01:16 PM. |
10-04-2013 | #69 |
Re: engine wear
It's all about respect I think. Here we go again.
Beware of trolls.
Thread Tools | |
Display Modes | |
