View Poll Results: Which coil packs do you have? | |||
AC Delco | 53 | 71.62% | |
Accel | 4 | 5.41% | |
MSD | 17 | 22.97% | |
Voters: 74. You may not vote on this poll |
Thread Tools | Display Modes |
10-18-2012 | #11 |
Re: Which coil pack do you have?
MSD
10-19-2012 | #12 |
I had originally changed out my OE coils for Jegs coils when I did my injector replacement. Subsequently I changed out the Jegs coils, after 3 yrs, for GM coils. The GM coils have been in there for about 32k miles and seem to be just fine. I didn't see any evident difference between the two brands by looking at my plugs, AC 41-602's, which I change every year.
The reason for going back to the GM coils was that they are specifically for an LT5, or so GM says; where the Jegs coils had other applications besides an LT5. I figure the environment in the valley of an LT5, for the coils, is fairly harsh temperature wise. Tom
10-19-2012 | #13 |
Working on a Z now that has Screamin Demon coils and nology wires (really different looking wires).
Daniel |
10-19-2012 | #14 |
Good point. I wonder how much testing went into the non-OE coils, being used on the LT-5, other than our members here. From what I've read it gets PD hot under there.
Joe 1990 Bright Red ZR-1 #2599 |
10-19-2012 | #15 |
You don't happen to have pics or a p/n would you?
10-19-2012 | #16 |
I've had the same set of MSD coils and wires for the last 3+ years. Also used MSD coil and wires on my 84 HEI system together w the MSD 6A box.
The 6A finally died after 10 years.
10-19-2012 | #17 |
A very timely question for me. A month ago I installed 4 new MSD coils and got 8 misfiring plugs. A switch back to OE Delco works fine. The MSD were made in.....China (No!!!!). Advice to myself: dont swap for the sake of 'not having to go under there again' (you will regardless and get used to it) and if you have a problem with coils, use OE parts.
10-19-2012 | #18 |
10-20-2012 | #19 | |
10-21-2012 | #20 | |
Nology Hot Wires
CJ Daniel [B]1991[/B] ZR-1 #834 [COLOR=royalblue][B]Steel Blue Metallic/Steel Blue[/B][/COLOR] [COLOR=red]Frank Approved ZR-1[/COLOR] [SIZE=1]- Ported air horn, throttle body, plenum and injector housings (Tommy Morrison)[/SIZE] [SIZE=1]- FIC SS Injectors / Nology hot wires / Screemin Deamin coils[/SIZE] [SIZE=1]- Fluidyne aluminum radiator and 9 row aluminum oil cooler[/SIZE] [SIZE=1]- 4.10 gears / Fidanza light weight flywheel / Hurst short throw shifter[/SIZE] [SIZE=1]- Stainless Works long tube headers / Borla exhaust with x-pipe[/SIZE] [SIZE=1]- DRM Coilovers / 32mm front 26mm rear sway bars[/SIZE] [SIZE=1]- ASM bolt in 4 point roll bar[/SIZE] [SIZE=1]- 93 ZR-1 Sawblades[/SIZE] |
