12-06-2013 | #71 | |
Re: TB coolant crossover,any disadvantages?
You do not eliminate any vacuum line unless you have eliminated the secondaries Install 1/8 inch NPT allen head pipe plugs (21/64 or 11/32 drill) two each side of Plenum (Two each TB Coolant and Injector Housing (IH) Coolant). The associated two IH coolant ports in the IH should also be plugged on each side. Total six coolant ports plugged One each side TB, One each side Plenum, One each side Injector Housing. See Summit Racing for Aluminum Pipe Plugs. See item 4 of LT5 Eliminated Systems |
12-06-2013 | #72 |
Marc says 20' F, 90% RH.
Under those conditions, I bet with hammer down (high velocity through the TB), you'd be GUARANTEED icing. At light throttle, who knows. I'd be interested in the test procedure parameters...
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] |
12-06-2013 | #73 | |
I would guess Marc drove the Z at all throttle positions for a test proven period of time at ambient 20 deg F with 90% humidity (the 90% humidity is pretty severe regarding icing). Marc uses the bypass to make sure no one will come back and suggest a coolant filling technique failed because of his TB coolant elimination. the throttle body has no problem with ice when the ambient temperature is at 20 degrees and the humidity is 90% Marc bypasses TB coolant and I eliminate TB coolant with NO bypass with my coolant filling technique that absolutely eliminates the potential for an air locked water pump. See Getting the Air Out Simplified TIPS Last edited by Dynomite; 12-06-2013 at 10:32 AM. |
12-06-2013 | #74 | |
I was having an idle issue so I pulled the plenum. Didn't find any obvious vacuum leak. All of the plastic hoses and rubber couplers look good. I'm going to put wire ties and silicone on all the connectors and rubber hoses. Had my injectors flow tested, four bad injectors. Ordered new injectors from FIC. Decided for now to remove the TB coolant hoses to dress up my polished plenum. |
12-06-2013 | #75 | |
1. With plenum off disconnect the vacuum lines one at a time starting from the pump and hold your finger over the end of the vacuum line. The pump should shut off and stay off. 2. Now go to the next suspect connection and do the same. 3. Once you get just past the leaky connection, holding your finger over the end of the vacuum line will not stop the pump from recycling. You have now found the leaky connection Usually the rubber connectors leak from age (hardened rubber). |
12-06-2013 | #76 |
What do I do about the fuel pump coming on with the key on and the plenum off.
I was going to check the secondary actuators but I thought about the fuel lines being off. Oh yea, I'm new at this. |
12-06-2013 | #77 | |
You can check all vacuum line connections by just tipping the plenum up in front without disconnecting any DIS connectors or vacuum connections at rear of Plenum.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-06-2013 at 12:35 PM. |
12-06-2013 | #78 |
Yea but I've got mine all apart to replace injectors.
I'll check that after I put the new injectors in and connect the fuel line. |
12-06-2013 | #79 | |
Excellent point on turning on the key with fuel lines disconnected Oh...if you have fuel lines disconnected from the fuel rails they tend to leak fuel as fuel tank pressure (Vapor Pressure) changes in the fuel tank. Loosen the Fuel tank cap to solve that issue.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-08-2013 at 01:17 AM. |
12-08-2013 | #80 | |
Cap OFF on the Z didn't get it. 4rth day, more gas I ended up dis-connecting feed + return lines @ the tank.
