07-07-2014 | #1 |
A/C gauge readings
I thumbed through the Service Manual but didnt see what i was looking for.
What should the high & low side gauges read when the system is fully charged? this is for a 1992 with a R12 system that is all original. many thanks! |
07-07-2014 | #2 |
Re: A/C gauge readings
What is the Ambient Temperature outside? Humidity?
This should help
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
07-07-2014 | #3 |
Keep in mind that your pressure is actually going to be a little higher than what the PT chart says unless you have a big box fan moving air across your condenser.
Robert J. DeMarco [SIGPIC][/SIGPIC] [COLOR=blue]G[/COLOR][COLOR=red]rand[/COLOR] [COLOR=blue]S[/COLOR][COLOR=red]port[/COLOR] Registry Lifetime Member NCM Lifetime Member #2655 Pacecar Registry Member [COLOR=red]ZOOM Charter Member - ZR-1 Owners of Michigan[/COLOR] [COLOR=plum][I]ZR-1[/I] Registry member since 2012 [/COLOR] [COLOR=black]1990 LPE "368" Aerobody ZR-1, Last ZR-1 built by John[/COLOR] 1991 Callaway Aerobody ZR-1, DRM 500 1991 Shinoda Aerobody Spyder, 1998 Pace Car |
07-08-2014 | #4 |
Thank you everyone and don't know how i missed that chart.
Temps tend to be high 70's/low 80's, humidity around 45-50%. will make note of higher temps without a fan blowing across the condenser. as always this group is top notch and extremely helpful. big thanks to all. |
07-08-2014 | #5 |
Also looking at the PT chart you can see why R134a will put a bigger drag on the motor than R12
07-08-2014 | #6 |
