09-30-2014 | #1 |
AC Compressor Connector
I need to find the two wire connector for the AC Compressor, anyone know where I can get one? this is the one on the actual compressor.
Thanks
09-30-2014 | #2 |
Re: AC Compressor Connector
Lee,
I have GM connector catalog in PDF. I look up and identify connector and corresponding GM part number then run search in ebay. Once you have the part number finding one is pretty easy. Send me your email address and I will email the PDF. byongyun@gmail.com |
09-30-2014 | #3 |
Found the web version where you can look for connectors:
http://www.acdelcotechconnect.com/pa...tails-catalog/ |
09-30-2014 | #4 |
Thanks Yun!
09-30-2014 | #5 |
The information I had ended up being the harness end of the connector I believe and the compressor side should have "male terminal" and a female shell. There were several number changes and it only had '92 applications originally so I just started over.
It should be this: http://www.mouser.com/ProductDetail/...BjZOg7MQ%3D%3D In this pdf search 12162343 and the connector body and the mating connector will be side by side and you can confirm by appearance. This is changed part # information from some older documents but I believe these should be correct. http://delphi.com/connectors/assets/...ure/met150.pdf The PT561/12125649 is expensive but I believe likely correct, at NAPA that would be an EC1151 - I believe this connector was used most everywhere on many other vehicles. I seldom use pigtails, I don't buy from Mouser often either but their images and info is easier to come by than the people I buy from. I can't see the end view of the PT561 so it's difficult to confirm. Last edited by WVZR-1; 10-01-2014 at 05:18 AM. |
09-30-2014 | #6 |
I will take some pics and look for parts #s tomorrow...thanks
10-01-2014 | #7 |
Terminal Supply has most if not all of the OEM connectors.
10-01-2014 | #8 |
I believe that Terminal Supply has a location very near "LGAFF" so that could be a good choice. They have the connector in black likely 12162000, I'd use 12045773 terminal and I don't know what color of seal you have, I'd guess blue maybe white but they should have all. Here's their 150 series parts:
http://terminalsupplyco.com/Store/De...228#Categories They're likely closer to -=Jeff=-. Last edited by WVZR-1; 10-01-2014 at 05:47 AM. |
10-01-2014 | #9 |
That's awesome, about 25 minutes from me....actually I lived around that area for about 5 years, never new they were there!
Thanks
10-01-2014 | #10 |
It won't be your "last" visit, it's good to have a vendor like that close by. My parts are 3 days USPS from me and I always thought that was good. I don't know how extensive their inventory is in every location but I would think these parts should be on the shelf.
