10-06-2014 | #41 | ||
Re: Pulling the Plenum for the first time...
After that, it was ROCK steady 675 (with the TB 2' gasket block, which told me that all else was in perfect tune order).
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 10-06-2014 at 09:04 AM. |
10-06-2014 | #42 |
The LT-5 sucks so well at idle that it doesn't take much to have a vacuum leak.
How often does your secondary throttle vacuum pump come on w key ON?
10-06-2014 | #43 | |
I have leaking fuel from under my plenum. It didn't do this the night I got the work complete, and it didn't leak yesterday. It must have done this overnight. So I guess the plenum is coming back off?
Looking for a ZR-1 1985 Yamaha RZ350-NOT STOCK 1971 Yamaha AT1-Middle of a restoration |
10-06-2014 | #44 | |
10-07-2014 | #45 | |
I am working through getting everything that would possibly leak air ziptied very tight.
10-07-2014 | #46 |
I put the intake back on. The car sometimes hunts for an idle. Going up and down just llittle bit. Everything is ziptied tight or clamped down.
Should I try blocking the intake port with some cardboard? In unrelated news I didn't have the coolant hose to the intake manifold tight and it sprayed coolant everywhere. Whats the best way to clean that up?
Looking for a ZR-1 1985 Yamaha RZ350-NOT STOCK 1971 Yamaha AT1-Middle of a restoration Last edited by Billy Mild; 10-07-2014 at 10:52 PM. |
10-07-2014 | #47 | |
Dropped a socket (ask Paul W on the particulars), and had to pull the INJ / rails. Gas dried a lubed O-ring, and it sheared off nice and clean on rail re-install. Fuel LEAK!!! And AFTER one successful FP test GRRR
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] |
10-08-2014 | #48 | |
So I drove the car this morning, look like my coolant tank is leaking just a wee bit. Need to put some more JB weld on it again. Other than that the car ran smooth. Before the car was fully warmed up the idle would go up a little bit and back down. I drove on the highway for about 20 minutes and then the idle was rock solid when at a complete stop. If the car was rolling at all the idle would be increased to 1,300 RPM.
10-08-2014 | #49 |
Don't think you are the only one that has had to go back in right after a plenum pull. Ha! I fixed my vacuum leak, cleaned everything up, and then really had a chance to start driving mine just to discover that my injectors were going out if you drove it for more than 20 minutes! I pulled it off the very next day.
Always buy a second set of gaskets to have in 'stock'. |
10-08-2014 | #50 | |
[/QUOTE]I drove on the highway for about 20 minutes and then the idle was rock solid when at a complete stop. If the car was rolling at all the idle would be increased to 1,300 RPM.[/QUOTE]That is high idle coast down issue - betcha. You gotta' get the memory / calibration module re-coded.
