06-29-2015 | #11 |
Re: A little wot video of my Z !!
We loved it!
Ami calls them "victims", and would hammer the Turq Monster just like that, given the chance!
06-29-2015 | #12 |
Well, Ami says she doesn't have lace on her panties...
06-29-2015 | #13 | |
06-29-2015 | #14 |
TMI.
06-30-2015 | #15 | |
when I did the headers, it was pure muscle on deccel. I do have a short clip of the popping Ill post in a few seconds... |
06-30-2015 | #16 |
Heres an old video my friend made with his android phone .. you can hear the sound while decelerating.. no popping at all
https://www.youtube.com/watch?v=gSfP1PJI304 And heres a short clip from the other day of the snap crackle and pop.. https://www.youtube.com/watch?v=M8AnmlUNxNU |
06-30-2015 | #17 |
The snap,crackle, pop comes from excess fuel being mixed w fresh air sucked into the exhaust due to the high vacuum created on decel. Ever see any ricer with a "fart can" that isn't completely BLAAAAACCCK from the soot of too rich a mixture?
06-30-2015 | #18 |
My tips don't blacken much at all but from what I know and can google.. that's the cause as you mentioned. Theres a dramatic difference from the first video though.. none at all.. and just excessive in the re-tune after the top end porting/secondary elimination
06-30-2015 | #19 |
Eliminating secondaries really doesn't have anything to do with it. On decel, the throttle is closed and secondary injectors are shut off. What happens is that with the changes, the fuel map needs to be modified. I have no secondaries, ported heads, more aggressive cams, headers blah blah blah. No gurgling.
06-30-2015 | #20 |
If all you have is "popping" on decel, then it's probably not an issue with Marc forgetting to enable that feature. Mine was BACKFIRING!!!! I mean, pretty much every time I depressed the clutch pedal (even on slow 1-2 upshifts) the car sounded like it was going to explode. Popping on decel is just your low-restriction exhaust...my stock Stingray even does that when I have the valves open.
