Old 04-24-2017   #1
ALLTHECAMS
ALLTHECAMS's Avatar
Default Intermittent DNS
So I now have the intermittent DNS (dreaded no start) on my 91 Z. I want to try to bypass the clutch safety switch to see if that helps. Can I just unplug it and jumper across the plug or is there more to it?
Sent from my XT1080 using ZR-1 Net Registry mobile app
1991 ZR-1 #520 Arctic White/Gray
ALLTHECAMS is offline   Reply With Quote
Old 04-24-2017   #2
Default Re: Intermittent DNS
Is it DNS when hot only? If so.. starter contacts
Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback
Old 04-24-2017   #3
QB93Z
QB93Z's Avatar
Verify that both battery terminals are clean and tight. Disconnect any after market systems attached to the battery terminals.
Put the ignition key to ON, Engine not started. Note the battery voltage on the instrument panel. Turn the key to start, while watching the battery voltage meter. If the needle does not deflect, then investigate the starting circuit, ie clutch switch, VATS, TDS.
If the volt meter does deflect, it means that the starter solenoid is energizing but the solenoid contacts are not passing current to the starter motor. Rebuild the starter solenoid or replace the starter.
NOTE, keep this procedure handy because it has to be done when the car won't crank. For an intermittent problem like you stated, you will have to wait until the next failure.
Good luck,
If it isn't fun, you aren't doing it right!
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 04-24-2017   #4
ALLTHECAMS
ALLTHECAMS's Avatar
Yes so far its only when hot and not every time. Thanks for the advice. Hoping I don't have to pull the plenum again.
Old 04-25-2017   #5
RICHARD TILL
EXACTLY the same symptoms I had when the starter solenoid contacts were dirty.
Old 05-10-2017   #6
ALLTHECAMS
ALLTHECAMS's Avatar
OK, so it happened again. I watched the volt meter and the needle didn't move when I turned the key to start. I was able to get a push start. What's the next step?
Old 05-11-2017   #7
QB93Z
QB93Z's Avatar
TDS is the theft deterrent system, the resistance chip in the ignition key that is checked to allow the computer to allow the starter circuit to energize.
The next step is to rebuild the starter solenoid or replace the starter.
Old 05-11-2017   #8
ALLTHECAMS
ALLTHECAMS's Avatar
OK now I'm confused LOL. In your first post you said if the needle did t move it wasn't the starter but to into the clutch safety switch or VATS? Sorry but I'm a dummy when it comes to diagnosing electrical issues.
Old 05-11-2017   #9
If it is Hot start only, it is the contacts of the solenoid. I chnaged the wiring a bit to minimize the solenoid electrical path, I still ended up pulling the starter and replacing the contacts.. The Challenge is diagnosing while hot..
But because it is only when hot, the contacts make more sense than the clutch switch
Old 05-11-2017   #10
ALLTHECAMS
ALLTHECAMS's Avatar
OK thanks
