05-03-2019 | #1 |
Next question.......ABS light.....how to disable?
Hello all,
My car had its ABS disabled years ago when the front brakes were installed. Any way to get rid of the unsightly service ABS light in the info center? As always, thanks in advance! Tony Sent from my iPhone using ZR-1 Net Registry |
05-04-2019 | #2 |
Re: Next question.......ABS light.....how to disable?
Pull the light bulb
05-04-2019 | #3 |
Reconnect the ABS ... on my 91 there is a power connector in the cubby behind the driver's seat. There is no good reason to disable the ABS unless the system is defective and no parts are available.
05-05-2019 | #4 |
Thanks guys, I don’t see a way to connect it back up since the original front brakes are long gone.
05-05-2019 | #5 |
has the ABS controller been removed too?
05-05-2019 | #6 |
Um, ABS sensor is in the bearing assembly, my front OEM brakes are long gone too, my ABS are fully functional still. Get yourself a Factory Service Manual. It will prove useful
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
05-05-2019 | #7 | |
H
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. |
05-05-2019 | #8 |
Thanks guys I am still new to this car. I do see where the wires mount to the hub. I saw a loose connector and I assumed it was for the ABS.
That being said, if the ABS is behind the passenger seat in the compartment the whole unit has been removed. Sent from my iPhone using ZR-1 Net Registry |
05-05-2019 | #9 | |
ABS is behind the Driver Seat, not the passenger seat
05-05-2019 | #10 |
Under the tray and possibly some insulation.
H
