06-27-2019 | #1 |
NCRS Newbie
well, after getting the car back to its former glory mechanically/cosmetically....I've made the decision to submit my 91' (#1631) for NCRS flight judging. I purchased the judging manual and have been through it a couple of times along with read all the threads in "NCRS for ZR-1's" section. I plan to do a full electronics function test as soon as my Bose system returns from servicing.
Work completed so far... -fuel system has been upgraded to withstand ethanol ( injectors/pumps/filter) -all fluids have been replaced -all gaskets,o-rings from the long block on up have been replaced. -top end has been refinished ( original bolts retained) -paint correction completed -has original wheels ( valve stems, sensor, sensor stickers) -Tires are date coded early 2000's and have plenty of tread @ 9,600 miles -interior is liek factory new with top hold down strap. -Bose Gold system is getting a complete rebuild as I write this. -A/C to be recharged soon. still holds vac. -ALL electronics work ( except the bose system for now) -sport seats are 100% functional -FX3 suspension 100% functional -Jack, storage bag, spare have never been used. -Build sheet/window stickers ordered form NCM. Under dash build sheet was shredded. Tank sticker still there. -headlight motor gears have been replaced/upgraded. My flight judging is set for August and I have a few questions for the veterans in the group. 1) how large of a fire extinguisher should be used and where can it be stored/mounted? 2) I'm a little fuzzy as to the center console content requirements. The only item included with the car was the top removal tool but I've been in touch with a fellow member that has some parts available. 3) How are driving points tabulated and do they effect the score significantly? I'll be towing the car enclosed from Denver. I'm open to any other suggestions, pointers or comments. I feel the car is deserving of the judging process. I just want to make sure I present it as well as I can. Thanks! -=MIke |
06-27-2019 | #2 |
Re: NCRS Newbie
Mike, do not mount the fire extinguisher just have it with you. Driving points and non original tires are explained in the Judging Reference Manual. It’s available through the NCRS store. The tires are a standard deduction which means whether you have a 1953 or a 1993 the deduction is the same. Have a battery cutoff and a NCRS sticker these with the fire extinguisher are a free bonus 10 points. Have a Delco battery and Delco oil filter. I am the National Team Leader , if you need anything else email me or call. I’m in the Restorer.
Tom |
06-29-2019 | #3 |
Re: NCRS Newbie
The most important things...………..
1- Learn so much more about your car, as the judges will almost always share things with you that you likely never would have known. 2- RELAX, points are just points. Don't fret over 1-2 point deductions. 3- ENJOY IT! You will likely remember it for years to come, so make it many good memories, and make some new friends! Best of Luck! Marty |
06-29-2019 | #4 | |
Re: NCRS Newbie
06-29-2019 | #5 | |
Re: NCRS Newbie
and.... Don‘t forget to ask how many ZR-1s have obtained Top Flight awards 😋 NO! I won‘t shut up about that... |
07-01-2019 | #6 | |
Re: NCRS Newbie
My plan is to prepare it the best I can and enjoy the experience. Doing the cosmetic top end refresh while I was upgrading the fuel system has taught me a lot about the car already. Forget undervalued, I think these cars are just under appreciated! everyone thats ridden in the car is amazed....and it s stock......for now. |
07-01-2019 | #7 |
Re: NCRS Newbie
Let us know what they thought
of the top end refinish. That‘s the only thing I can‘t undo to get back to where my car was when I went thru the process. In spite of my concerns with NCRS‘s (arrogant, Head Judging Chairman) information policies, the Top Flight experience was a positive one. The judges (especially Tom Barr) were fair and knowledgeable!!! |
07-01-2019 | #8 | |
Re: NCRS Newbie
I was able to remove all the factory torx fasteners w/o a problem. Cleaning, running through a die, coating with a rust prevention coating and loctite ( where applicable) took some time. But what part of this project didnt. still looking for a factory replacement lower air dam ( spoiler) assembly. mine IS original but a little rough around the edges. |
07-02-2019 | #9 |
Re: NCRS Newbie
I would suggest to start at a chapter meet if possible. Some chapters have better ZR-1 folks than others. Try to get at least the AC Delco replacement parts - Black Oil Filter, Air Filter and battery. You will still take a hit but it will be less. As for tires make certain they are the same size, I would recommend Goodyears F1s if at all possible. I will have a set of Goodyear Gatorbacks available after Nationals but they are mounted on 90 rims at present. Make certain all options work, seat bladders, cassette, CD, etc. as operations are the easy points to get. The Performance Verification is another thing entirely but one step at a time.
You do NOT need a Pizza box for judging and only one top gets judged. Original parts with a little wear and tear do better than perfect new parts that are not correct (you mentioned SS fasteners). I can make some other recommendations if you are interested, let me know. BTW, I am going after my Dave McClellan Award at Nationals in two weeks. I have a Dave Hill Award for my 94 Copper Convertible so this is the second car to attempt it.
Joel Tampa/Rockledge, FL Present Collection 1969 350/300 AC Convertible 1972 454 Coupe 2nd Owner 1988 KOH EX5006 - ZR-1 Prototype 1990 ZR-1 #277 NCRS Dave McLellan Award 2019 1994 Copper Convertible NCRS Dave Hill Award 2012 2001 Z06 122k miles |
07-07-2019 | #10 |
Re: NCRS Newbie
NCRS used to have the judging sheets on their website. If they are still there donload a set and use them as you go through the manual. The biggest point hits are in Operations. As Joel mentioned above make sure everything works as described in the NCRS manual.
Your best bet is to go to a Chapter level or Regional meet. The level of expertise at a Chapter level is highly variable. Regional would offer a higher level of competence. As Mystic mentioned above there are very competent judges and there are also some arrogant know-it-alls. Take your car to the meet, get your judging sheets back and decide which items, if any, are worth fixing for your next attempt. Lastly, after your car is judged, make sure it gets into the NCRS database. It is the meet judgiing chairman's responsibility to get the information to the National organization. Some times this does not happen and the National Organization will not acknowledge your flight award. This happened to me in 2010 and after a lot of finger pointing as to who was to blame (no one would accept responsibility), I had to start all over again. Good luck and as Marty said, enjoy. John
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) Last edited by jrd1990zr1; 07-07-2019 at 11:05 PM. |
