10-28-2019 | #1 |
brake question
I will be changing brake fluid ( its old) thoughts on me switching to Dot 5 ? thanks
10-29-2019 | #2 |
Re: brake question
10-29-2019 | #3 |
Re: brake question
thanks Bro
10-29-2019 | #4 |
Re: brake question
You should use DOT3, DOT4 and 5 are chemical more aggressive to the rubber seals in the brake system (rubber swelling).
Best thing in life is a ZR-1 ride |
10-29-2019 | #5 |
Re: brake question
10-29-2019 | #6 | |
Re: brake question
Also, DOT5 fluid is silicone-based and is an excellent choice for old "non-ABS" classic cars where preventing corrosion inside the brake system is the prime concern and braking performance is secondary. DO NOT use DOT5 silicon-based brake fluid in any vehicle with ABS. The viscosity of DOT5 fluids is incompatible with the rapid fluid movement required for an ABS to operate properly.
10-29-2019 | #7 | |
Re: brake question
11-05-2019 | #8 |
Re: brake question
I used Pentosin DOT 4 when I serviced my brakes last spring. It has a dry boiling point equivalent to most DOT 5 fluids (which are never to be used with our braking systems.)
11-05-2019 | #9 |
Re: brake question
Thanks for the replies , I still havent gotten to the brakes yet ( been working OT). Maybe I'll get to it over thanksgiving.
11-05-2019 | #10 |
Re: brake question
The talk of seal compatibility with fluids reminded me of this page from the "Fluid Power Data Book." Not sure if it exactly applies here or not, but it's still helpful information that has served me well over the years.
