Old 03-02-2020   #1
Corvette95
Corvette95's Avatar
Default List of things to do while 90 is torn down..sugestions
I finally have the 90 basically completely down. Interior is out including dash and booster. All interior parts.I have to remove door glass and hood clamshell for paint. I need to adjust the hood as it is scraping right hinge, I want to bleed all the fluids (pump the rear end fluid out) and I suppose the remove the brake fluid I use a tech1A? Thought about having the working booster rebuilt- it is working? Headlamps are already rebuilt last week, I have never replaced the parking brake linings... I have new rotors and pads - nothing bought for emergency brakes. I would like to find a good used third brake light, replacing/rebuilding hatch struts. putting in new console, radio bezel, and shift knob (correct parts) . Removing weatherstrip and guide channels for paint. Seats are out with new covers from Al Knoch on the way (I am concerned with the installers ability - even though he says he is knowledgeable) . New seat air bladders, switches and pumps rebuilt. All new Bose installed. I have a new started once I am under Plenum. A/c Works, wonder if I should have compressor checked while it is off. Sending belt tentioner to Marc H when it gets off this week. I need to find a red spare tie down. I need A-pillar NOS weatherstrip. What else can I do while it is apart? The injectors are supposedly less than a year old. Is the air filter the same size as the 90 L98 motor...I think I need a filter for the smog pump inlet?
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 03-02-2020   #2
Ccmano
Ccmano's Avatar
Default Re: List of things to do while 90 is torn down..sugestions
How does the instrument cluster lighting look? The bulbs go out and the LCD goes dim. Batee.com is the go to for those issues. Also how do the seatbelts look? Frayed or overly worn belts should be replaced. Is the FX3 shock system good? No dash lights or codes?
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Ccmano is online now   Reply With Quote
Old 03-03-2020   #3
Corvette95
Corvette95's Avatar
H
All instruments are already on way back from Batee FX3 Good, no lights, seat belts are good (low mileage) . The CD head unit was all working but sent for upgrade anyway. I had all new amps and bose, those are already installed. I am doing the airbag grounds . I am wondering about brake booster, heater core, air box, I put a new hood release cable(s) in but can't get a good fit - I used GM cables. I have new seat bladders and seat leather on the way, I don't have a interior shop here where I moved so I had to call around. I have a shop to install them but nervous about them putting the air bladders in correctly and the solo side seat bolster (90) . I rebuild the air pumps although one makes more noise than the other. I am replacing all the weatherstrip but only have GM NOS B-pillar, have found two GM A-Pillars but neither place will call me back. White racing being one of them. I guess I should just write them off the list at this point. I see the sticky on them. I am trying to decide on headers and exhaust but don't want loud or a check engine light so I need the O2 sensors to work.
Old 03-03-2020   #4
rush91
That sounds like a nice spring project. Hope you post pics up when she is done! And I wish you good luck with Al Knoch. I wouldn't recommend him to anybody, but you may have a totally different experience.
Old 03-04-2020   #5
Corvette95
Corvette95's Avatar
I hope the new leather is good, I am having it install locally.
Old 03-04-2020   #6
Corvette95
Corvette95's Avatar
Since I have posted so much about this 90 I picked up...here are some pics of before and current, hopefully the "finished" file will be ready by end of April.
Old 03-04-2020   #7
I'd slap some Dynamatt down while you have the carpet out / door panels off.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 03-04-2020   #8
Corvette95
Corvette95's Avatar
Not a bad idea!
Old 03-04-2020   #9
32valvZ
32valvZ's Avatar
Your 90 looks like a 91
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 03-04-2020   #10
Corvette95
Corvette95's Avatar
Yeah, PO put 95 moldings , wheels, fenders and front bumper. I’m probably gonna leave it that way as it will be my fun Z not an NCRS car although I do like to keep as stock as possible. If I do, I will put 95 side emblems on it .
