01-17-2021 | #1 |
Zr1 fuel pump 1 not working
I have a 1990 zr1 that sat for a few years. I changed injectors and fuel pumps. The car starts and gets up to a certain temperature and loses fuel pressure and stalls. When I start the car cold and I pull the fuse from the block under the passenger side dash it loses fuel pressure and stalls. I do not think this should happen because the fuel pump one should keep pressure and keep it running. I connected the Lead coming out of the firewall to the positive on the battery and still no change car still stalled when it got warm.
Any Ideas? Mike |
01-17-2021 | #2 |
Re: Zr1 fuel pump 1 not working
Pull the FP2 fuse and see if it starts in the same manner. If it doesn't start you have a bad FP1 pump. The other possibility to check are the hose clamps on the pump assembly or a cracked Y block on the pump assembly. I'm betting it's a bad FP1 pump.
H
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. |
01-17-2021 | #3 |
agreed, you can also check initial fuel pressure with fuel pressure gauge, it will pressure up to 55psi then drop about 5 psi if both pumps are working, no drop equals one pump bad. (this was part of this morning project for me BTW)
01-24-2021 | #4 |
if anyone needs pumps, I gotz em cheap. I upgraded on the LSV and my fresh stockers are no longer needed.
95 390 LPE ZR1 (505 rwhp) LSV = Lingenfelter Super Vette Twin Turbo 2003 Z06 (800 RWHP) |
01-25-2021 | #5 |
Mike,
We can help but we need to know the fuel rail pressures. Get a gauge set from harbor freight. Read the stickies on fuel pumps here on the forum. I think you have a cracked hose or fitting in the tank. We need more info sir.
01-26-2021 | #6 |
As others have said, very likely pump 1. The LT-5 runs on both pumps until temp comes up and engine switches to closed loop, then it turns off #2 and only runs on #1 unless demanded at WOT by ECM. Make sure you check the bulkhead connector as well (for corrosion) when you have the assembly out.
Sent from my SM-G950U using ZR-1 Net Registry mobile app Last edited by jss06c6; 01-26-2021 at 06:16 AM. |
