Old 02-10-2021   #21
Vette73
Default Re: Hesitant on acceleration and nothing when you mash the throttle
Just an update....Got the fuel pressure gauge on Sunday....Battery very weak will not turn over....Only charged to 35% and dropping so I need a battery...Had car for almost 7 years now..I guess its about time..
Will keep you posted...
Old 02-10-2021   #22
lfalzarano
Batteries normally only last 3 years.
Lou[COLOR="Red"][B][SIZE="4"][/SIZE][/B][/COLOR]
Old 02-10-2021   #23
NOT to hijack this thread, but using a Battery Tender, it is programmed to de-sulfate (pulse) the battery periodically. The result has been batteries in all 3 Vettes being "fresh as a daisy" for 13+ years. Just sayin....
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 02-10-2021   #24
lfalzarano
Batteries last longer in cold weather states. I use a battery tender, but sometimes they fail or become marginal. I?ll be hunting down a new battery when it is safe for me to shop in public.
Old 02-10-2021   #25
32valvesftw
In general I get about 3 years on batteries down here, the heat is a killer. This year I have insulating blankets on two of them, not sure if that will really matter much. On the vehicles I use a tender on it stretches a little. I just went to AGM on two other cars, I hope they last a bit longer.
Old 02-12-2021   #26
Vette73
Ok fuel pressure at idle is at 21psi...I know it should be around 43 at idle....Did not drive it yet with gauge Attatched....Lots of snow and ice...
Guess the next thing is check the draw on each pump with a multi meter ?
Let me know...Thnx for all the help..
Old 02-12-2021   #27
wfot
wfot's Avatar
Dude, the pump/pumps are done. 21 PSI warm, cold, hot, any reason pump/s = B A D.
wfot is offline   Reply With Quote
Old 02-12-2021   #28
I?d put vacuum on the regulator and see if it holds.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-12-2021   #29
Vette73
Weird thing is I changed these a few years back.......I had an issue with the car once it got to 170 degrees it would run like crap....
It wasn't the pumps....It was a sensor near the headers.....Thought it was the pumps...
Will try checking the current with the meter...Pulled hose off regulator and its dry...No fuel leaking if that helps...
Old 02-12-2021   #30
jss06c6
Just a word of caution.. agree completely that if pressure truly is 21 psi, there is a fuel supply issue. I have had numerous LT-5's that don't read properly because the Schrader valve connection doesn't open properly when the fitting is attached...
