04-20-2022 | #11 |
Re: FS Single fuel pump conversion for LT5
Thank you for the nice words, it is greatly appreciated!
91-#1935 Black/black & gray, Haibeck 500 Cams by Pete |
04-20-2022 | #12 |
Will you be at the gathering?
ZR-1 #638/1991 |
04-20-2022 | #13 |
No, not this year.
04-28-2022 | #14 |
Matt B,
I can't send you a private message until you clear out your old messages, your account is totally full. Dan
04-28-2022 | #15 |
Well after having trouble with the stock fuel system (two pumps) in my ZR-1
I was going own make my own based on marks write up. But Flyman 27 offered single pump setup for the ZR-1. Well that made It easier for me a already made system that I could install with out to much trouble (getting out the two pump system).Brought the single pump system and installed It. Works great, but I noticed that the fuel pressure would drop as soon as I turned off car. Not a big deal, turns out there is no drain back valve . OK now my engine is a 368 cu.in. motor with 12 to 1 compression. Flyman 27 said just install a check valve from tank output to the engine. And problem solved, holds pressure starts in about 3-4 seconds and pressure holds for restart. I'am very happy with this system and would recommend it if your having issues with dual pump system. John 1990 white/black # 2546 one of a few 4l8OE EQ ZR-1's |
04-28-2022 | #16 |
04-30-2022 | #17 |
Done. Sorry, it all came together this time [emoji23]
ZR-1 #638/1991 |
05-07-2022 | #18 |
Got mine today. Thanks Dan for making, thanks Marc for bringing it [emoji3]
Looks awesome, can't wait to install it. Definitely great work!
ZR-1 #638/1991 |
05-07-2022 | #19 |
I saw Matt's at BG, what a beautiful job. Looks factory.
05-07-2022 | #20 |
Thank you for the kind words.
Dan
