Old 09-11-2023   #1
jw63
jw63's Avatar
Default WTB - ZR-1 Radio Antenna Bezel / Grommet
Looking for a replacement ZR-1 antenna bezel. Does anyone have an extra that they would part with?
Had to replace my antenna and learned the hard way that apparently this is a ZR-1 specific part.
-Jackson
'90 #413 Red/Red Sold
'90 #1583 Red/Red
jw63 is offline   Reply With Quote
Old 09-12-2023   #2
phrogs
phrogs's Avatar
Default Re: WTB - ZR-1 Radio Antenna Bezel / Grommet
I have one but what happened to yours if I may ask?
JOHNNY P
Currently own
Old 09-13-2023   #3
jw63
jw63's Avatar
I had a broken antenna mast...instructions on the new one said to remove the grommet in order to replace the mast with the antenna unit remaining in the car. I had purchased a replacement grommet online since I figured it might break apart when removing, and it did. Unfortunately, when I was finished replacing the antenna mast, I discovered that all of the replacement grommets online are for standard C4's.
I will send you a PM about the one you have.
'90 #1583 Red/Red
Old 09-13-2023   #4
jrd1990zr1
jrd1990zr1's Avatar
How do you determine the difference standard C-4 verses ZR1? Part #?
Reason I ask is I might have one.
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 09-13-2023   #5
jw63
jw63's Avatar
Here is a picture difference between the standard C4 one and a ZR-1 grommet.
If it's in its original GM parts bag, the part number is 14104620, I believe.
'90 #1583 Red/Red
Old 09-13-2023   #6
phrogs
phrogs's Avatar
They are slightly different due to the ZR-1s wide ***.
JOHNNY P
Currently own
Old 09-14-2023   #7
phrogs
phrogs's Avatar
Well I dug out the one I have in my stash and mind you it came from a ZR-1 But it looks like the normal car version so I assume someone replaced it with the base car version. I guess I didn't notice at the time.
sorry It's not the right one.
I have another one but its still on the car and I haven't parted out yet.
Old 09-14-2023   #8
Antenna grommet for ZR-1 has less slant angle on top because antenna location on rear fender is relatively flat on ZR-1s. They are different.
Old 09-20-2023   #9
Corvette95
Corvette95's Avatar
Once the OP gets their grommet, I need one too if there is another floating around.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 01-03-2024   #10
jrd1990zr1
jrd1990zr1's Avatar
I have two of these one in the GM box with #14104620 and a second without the box. The question is a fair price for this NLA part?
