![]() Join Date: Jul 2004
Hi everyone,
I've removed the plenum to switch out the starter motor and there's a lot of thick black grime underneath. Any suggestions for the best way of cleaning there? ![]() Also, this plastic clip crumbled when I moved one of the lines. Are they available anywhere? ![]() Thanks Dave
1991 #1516 Black/Black davidmkelly.com "Speed is often confused with insight." - Johan Cruijff |
![]() Join Date: Aug 2006
I use mineral spirit, a toothbrush and a lot of rags. Once cleaned, fresh injector housing gasket and positive seal at PVC hoses should keep it reasonably clean.
#3 | |
![]() Join Date: Sep 2016
Put duct tape over intake ports to prevent anything falling in there. Don?t have an oops.
Thanks, Steve. I did that a couple of minutes after taking the photo
I'd suggest if you're not in a hurry to get it back together pull everything out off,clean and put it back together.
