10-28-2018 | #11 |
Re: I thought I was special, but it looks like I need injectors....
Thanks Jerry, great info.
Does Jerry's sell injectors? |
10-28-2018 | #12 |
Thanks for asking Steve.
Yes we do, FIC. Jon Banner, the owner of FIC has always provided outstanding customer service. It's always nice to be able to reach a supplier & get answers from someone in the know.
10-28-2018 | #13 |
Yes,Jon is #1 as far as I’m concerned. The guy does business the way people used to do it.
10-29-2018 | #14 |
Thanks Jerry, that always makes it easy.
You don't have to explain to Jerry what that weird engine is, just ping Jerry and the parts are on the way. O.P., certainly if these are the original injectors, they should be done while you are in there. |
10-29-2018 | #15 | |
Have u ever asked Jon if he could provide the Injector Bias v BAT V compensation values for his injectors?
10-29-2018 | #16 | |
Re: “While I’m in there”.....another plenum pull.
10-29-2018 | #17 |
Thanks for the great injector info Jerry. I,m planning a different ZR1 build in the future using a fully ported/polished ( inside & out) top end LT5 I have. For now, I plan on using suitable aftermarket replacements on this car. I’m not going to go annal on the original parts & Ill keep whatever comes off it just in case the market wakes up, value increases, I can no longer drive & decide to sell it in the future.😂
And,as soon as I get my car done, I’ll be placing more orders to resurrect my dads 91, quasar Z. Then we’ll start dipping into the classics. Looking forward to retirement. Last edited by bowtiguy; 10-29-2018 at 09:00 AM. |
10-29-2018 | #18 | |
No, I have not. It's out of my knowledge & experience range! You know more about that than I will ever have occasion to use. He will be happy to discuss it with you though.
10-29-2018 | #19 |
I asked some time ago for that info and was told they either didn’t have it or it wasn’t necessary. For an injector shop it should be easy enough to determine what those values are. As a vendor, I thought u might have more influence for the request.
Accel and Bosch data is readily available, not sure about RCs. Altho the info on the Accels for the LT-5 has been hard to come by until recently.
10-29-2018 | #20 | |
My understanding is that if the compressor has not seen much use, the seals can dry out and leak. My 40k mile 91 spent most of its life in Florida so I would assume it had frequent AC use which is maybe why I didn’t have any leaks on the original compressor.
1991 ZR-1 #1900 Black/Black |
