#21 | |
![]() ![]() Join Date: Nov 2007
Attached is a chart listing over 20 flavors of "Mobil 1". There are several with the 1200/1300 ppm levels of phosphorous and zinc (ZDDP) levels in them as the oil initially recommended for the LT5s at the time of the LT5's manufacture. But, even so, one needs to be aware of the fact additive content for any one product is NOT always held constant. A word about projecting results from one architecture to another (i.e., pushrod vs. DOHC): The inertia of the valve trains is vastly different. In order to avoid valve train and valves from "floating" (i.e., loose constant contact between components - primarily at higher speeds), valve spring tensions that counter the direction and force of the lift motion must be sufficiently high to prevent float; keeping the integrity of the entire valve train at 100% at the maximum rpm. Inertia forces increase at the square of the speed (think: RPM) change rate. The point is, there is sufficient differences in the dynamics between pushrod vs. DOHC to make direct extensions of data from one architecture to the other somewhat ambiguous. Or, in other words, what will suffice for one doesn't automatically transfer to the other. I've experienced a cam going flat in a 350/350 SBC filled with API "SM" oil. Changing the cam out in that SBC was a piece-o-cake cost and labor wise, compared to an LT5. The thought of scrimping on ZDDP because this or that oil manufacture's hype doesn't give me a warm fuzzy feeling. Anywayz... Just a thought: it might pay to look a little further than brand name when making a product decision, no?
#22 |
![]() Join Date: Oct 2017
Spork,
I’ve seen your previous interactions and posts with other members and I won’t allow myself to get sucked into one of your meaningless argumentative rants. I’m done with this subject after this post. With that being said, My opinion on the subject is only free advice from a friend, albeit free advice from someone with 20yrs+ experience on the exact application in question. (Engine testing and durability). The LS by all rights is the Grandson of the LT5 in many ways, especially in machine tolerance specifications materials and assembly methods. There most likely is a better oil out there for each and every application, but 99.95% of us here will never have the ability to push any of these lubricants to their limits, regardless of the application. In my experience, Mobile-1 has proven to be an incredible product time after time. Sent from my iPhone using ZR-1 Net Registry Last edited by Ls7/Ls9 Test Engineer; 02-25-2019 at 02:11 PM. |
#23 |
![]() Join Date: Dec 2003
Science/Engineering Rule: empirical trumps theoretical.
Redneck Rule: If it ain't broke, don't fix it. Risk vs Reward Economics: Similar to PPM My Choice: Mobil 1. I have no need to experiment with a different product.
#24 | ||
Which Mobil 1 do you use in Other Vehicles? (I use Mobil 1 10W-30 in other vehicles). Quote:
![]() ![]() Thanks Paul Workman for the Information on Mobil 1 ![]() ![]()
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-25-2019 at 12:25 PM. |
#25 |
![]() Join Date: Mar 2004
I use Mobil 1 full synthetic on all my cars-trucks.
On the 441 I used the AMO1 10/40. When Pete did a total teardown on the engine he asked what oil I was using ? I told him AMO1. Pete quickly replied that the engine despite having 6-7K miles on it the bearings looked like the engine was never fired up.
#26 | |
![]() Join Date: Jun 2013
The LS architecture is nothing like the LT5. Any comparison between oil performance in the two is more anecdotal than anything. I lost interest in your post when you implied that because something is in oil in PPM it's not important. I'm curious what kind of engineering degree you hold? I don't personally know one single degree holding engineer that would make a comment like that. |
#27 |
![]() Join Date: Jan 2015
So, are all of these "acceptable" for 99% of us here (except the Racing 4T)?
I chuckled to myself when I first assumed our cars were "domestic", then reconsidered when I remembered where the engines were built and designed. :-) |
#28 |
![]() Join Date: Jan 2010
...assumed our cars were “Domestic”? It doesn’t get any more domestic than Stillwater OK... Last edited by Mystic ZR-1; 02-25-2019 at 08:47 PM. |
#29 | |
My LT5 is a 415 Stroker. I use Mobil 1 15W-50
I use Mobil 1 5W-30 for my 2016 Z51 Stingray Corvette.
#30 |
