Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Member Rides
Old 06-24-2018   #21
Karl
Karl's Avatar
Default Re: Beast #2 heads to Chicago!
Quick photo of parts....drm brackets and stock shifter going to zf doc tomorrow for modifications (shifter only).
Modified oil catch can inlet line.
Old 07-10-2018   #22
Karl
Karl's Avatar
Things are moving along pretty well. I have the oil catch can installed and just about all the upgrades have arrived.
I need to pull the plenum and check the connecting harness to verify the ignition module is connected properly. Hopefully it is not and is a simple cure for the code 16. The prior owner pulled the plenum to replace the coils and I assume the distributor ignition system harness was not plugged up correctly.
Edit:
Dyno run #1
https://youtu.be/AM5IKagZhUQ
Dyno run #2
https://youtu.be/wEXI8TvDCiU
Old 07-12-2018   #23
ZWILD1
ZWILD1's Avatar
Congrats Karl on a truly unique story/history to this car. Justin sent me all the info as I was looking at it also and almost decided to buy it. I think of it as fate. It was destined to come your way. That and my wife made it clear she doesn't like yellow on any car. Personally I think the yellow looks cool. Justin said it was a Viper Yellow Metallic not sure how that looks verses the Competition Yellow GM painted the cars. Cool car though.
91 Turquoise Metallic Haibeck 525 #0134
ZWILD1 is offline   Reply With Quote
Old 07-12-2018   #24
Karl
Karl's Avatar
Thank you for the kind words. The yellow looks like the yellow on the C4 Corvette. My favorite color is black but I like the yellow and it will do just fine.
Hopefully I will be able to beat or at least match Doug's best time in the car at the 1/4 mile soon.
Old 07-25-2018   #25
Karl
Karl's Avatar
Looks like the code 16 has been solved.
Old 07-25-2018   #26
just hope the pin doesn't break
Old 07-25-2018   #27
Karl
Karl's Avatar
Fingers crossed!
This Z is cleaner than the black one I had. Hard to believe considering the miles.
Old 08-26-2018   #28
Karl
Karl's Avatar
Beast #2 secondaries are gone and 16 new fuel injectors have been installed along with the performance upgrades.
This car will spin the tires in second gear from a slow roll at 15+mph.
I have a few miscellaneous things to do.
So far so good.
Big thanks to Pete for working on the car.
I am mechanically inclined but have no where to work on the car and I don't like waiting!
1/4 mile times are next along with another update.
Drive your Z!
#notrailerqueenhere
Old 08-26-2018   #29
Pete
Pete's Avatar
Your welcome Karl.
Enjoy her.
Pete
So far so good.
Drive your Z!
#notrailerqueenhere
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 05-24-2019   #30
Karl,
Just did an update to the catch can w the screen and steel wool. As for the inlet port, I had some rubber tubing that squeezes into the backside of the inlet. VERY tight fit. Don’t believe it’ll go anywhere.
