Old 04-26-2019   #21
WVZR-1
Default Re: WTB crank sensor connextor
Thanks for all the help.. I found it..
Casper Electronics #410016, I ordered a couple, if they work I can eliminate added wiring I put in my car..
If this does for you what you want it's I'd think the preferred. You know where you can go to get more and they seem to have the specialty terminals required. I'd be interested in seeing the contents in a snapshot. The eBay offering without service terminals etc I'd think NOT a wise buy!
Old 04-28-2019   #22
spork2367
It’s just an alternative for others who may be looking for one with a pigtail already attached so they don’t have to crimp their own terminals.
Old 04-28-2019   #23
I wish I would have found these about 6 months ago, either way, in this instance I want to pin them directly, the pigtail can also be useful. If someone made the Wide flat IM mate to connect to the harness that would be even better, but my feeling is that one is only used in our application
Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback
Old 04-29-2019   #24
It fits
Old 04-29-2019   #25
WVZR-1
What does the other end 'mate' to? You only show what appears to be an empty end with the 'pull to seat' attached on the other end. There had to be a purpose to this!
I was quite sure the 'pull to seat' would be correct.
It just uses the long male terminals with seals etc to wire?
Old 04-29-2019   #26
Yes uses male terminals and a seal on the end. I wanted to confirm the housing fits before I cut a working wire to connect it there.. There are 3 mate connectors keyed differently this works will all of them and you can use male or female pins. I will get a picture when completed
