10-29-2016 | #1 |
Differential Drain ?
Changing gears from 3:73 to 4:10. While I am at it I wanted to add a drain for the lube. Thinking about going quick and cheap, by drilling a drain hole in the carrier and using the Bat Wing bottom bolt as a drain.
Question is how well does this work, and does the Bat Wing cover bolt ever develop a leak? Going to use The Right Stuff RTV for the cover sealant. Thanks Jim |
