10-16-2011 | #1 |
Part Identifications
I picked up a few ZR1 parts a while back, in the box were a couple of parts I can't identify, can anyone help?
This looks to be an oil pump driveshaft, but I didn't think LT5s had a normal shaft like this. Maybe a distributor drive? Obviously it is a pedal for either the clutch or brake, I just don't know which. Any ideas? I also got a rear brembo brake kit, anyone know who might have made it or any information on it? It has a parking brake included in the hub, so it definitely isn't a normal C4 kit. Thanks in advance! |
10-16-2011 | #2 |
Re: Part Identifications
Looks like a custom kit allowing the parking brake to be retained however using Brembo calipers
10-17-2011 | #3 |
I agree with Daryll
Dennis Fierstein 90 ZR-1 #2562 Atomic-Z ZR-1 Net Registry Chairman of the Board ZR-1 Net Registry Treasurer |
10-17-2011 | #4 |
Also for pre-90 MY cars prob 86-89. Not ZR-1 specific unless its a mule ZR-1 narrow body etc
10-17-2011 | #5 | |
That pedal is a clutch pedal
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
10-17-2011 | #6 |
Thanks guys, appreciate the help. Didn't realize there was a change in parking brake between years on C4s.
10-17-2011 | #7 |
I agree with Jeff on the parking brake setup. Not custom, just 88 and prior C4 setup.
The shaft is an oil pump drive shaft from a Chevy Pushrod V engine. Could be V-6 or small block V8 or big block V8. Jep |
10-17-2011 | #8 |
Sorry, Make that 87 and prior. My Bad!!!
10-20-2011 | #9 |
The clutch pedal might be from a certain twin-turbo ZR-1 that was converted to an automatic. Just guessing.
10-20-2011 | #10 |
There was also a non- turbo ZR-1 in your Indy area converted to Automatic.
