Old 11-22-2019   #1
Flyman 27
Flyman 27's Avatar
Default Another No-Start Condition
This happened a couple weeks ago & I have been chasing it since.
One day the car just failed to start (cold). It turns over fine, just no fuel.
I jumpered the pumps & they run fine, and build pressure fine.
The pump relays are not getting power, neither are the fuses.
I did do a 10 minute "alarm bypass" procedure & it started right up and showed full fuel pressure. But as soon as I shut it off, it is back to having no power to the pumps again.
Been working on the interior & got to the point where I could drop the steering column.
So I tried the Vats bypass.
The key pucks read 683 (#3)
The closest resister was 674, I assume that is close enough.
I soldered the resister into the end of the conn on the strg column.
Tried to start it, and the engine will still not fire.
It turns over fine, it is just getting no fuel.
I pulled back out the resister to verify everything
The Chart reads "design" resistance = 681 Min = 650 Max = 728 My keys read 683 The resister reads 674, right down the middle.The keys are the ones I've been using ever since my column was rebuilt, maybe 2 years ago.
Where is the alarm function located?
Can it be replaced or by-passed?
Possible options??
Any ideas?
Cams by Pete
Old 11-25-2019   #2
onetinsoldier
Default Re: Another No-Start Condition
Have you put a fuel pressure gauge on it to see if the rails have fuel ?
onetinsoldier is offline   Reply With Quote
Old 11-25-2019   #3
Flyman 27
Flyman 27's Avatar
Also:
Went to see Mark Haibeck this morning, he was going to turn off the Vats system in my MEMCAL to eliminate that possability. But the Vats was already turned off in my MEMCAL.
The fuel condition is as follows:
Jumper from Battery to the pumps, pumps run & I have full pressure.
Jumper from Battery to underhood test lead, pumps run & I have full pressure.
Turn the key on (should prime) and pumps don't run & I have "0" pressure.
Turn the key to start & pumps don't run & I have no pressure.
I have also replaced both pump relays, just to be sure. NOS GM relays.
Checked all fuses, in box & under dash panel. All are good, replaced them anyway.
So my list of possibilities is getting short.
I was warned that it could be my ECM (hope not!).
I am at a loss as to what to test next.
That doesn't make sense to me.
Cams by Pete
Old 11-27-2019   #4
Flyman 27
Flyman 27's Avatar
Found it almost by accident.
The problem was intermittent and very confusing.
It ended up being the wire conn for the fuel pump sending unit.
It would test fine, then kick out.
I had the key on & was checking stuff & I could hear the pump kicking in and out.
So it is a simple fix, I ordered new weather-proof conns from Amazon & I will be good to go!
Cams by Pete
Old 11-27-2019   #5
Its usually the simple stuff first. We all have a tendency to escalate things.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 11-27-2019   #6
Flyman 27
Flyman 27's Avatar
The problem was intermittent, it would test fine, so I would ignore that area, then proceed. Then I would get other faults that didn't make sense, so I tested everything over. And again, it all tested fine. Then it would fault when I tried to start it.
It was not an easy problem to find because the "fault" kept moving.
I kept testing the circuits, but not the amp draw of the pumps. That is where I failed.
Cams by Pete
Old 11-27-2019   #7
billschroeder5842
billschroeder5842's Avatar
Ain't that the truth! I can scream APOCALYPSE faster than anyone!
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
Old 12-01-2019   #8
JThomas
JThomas's Avatar
Thanks for posting. I'm not as knowledgeable as most of the guys on this forum, but I learn a little bit each time I read something someone else has gone through. Glad you found the fix.
Joe Thomas
Corvette Club of Michigan
NCRS-Michigan Chapter Member
NCM Master Ambassador
Former NCM Board Member
1991 ZR-1 Melon Copper Metallic/Black
1992 ZR-1 Bright Red/Black (Sold)
1995 ZR-1 Bright Aqua/Gray (Sold)
2012 ZR1 Super Sonic Blue / Dark Titanium
JThomas is offline   Reply With Quote
Old 02-08-2020   #9
Corvette95
Corvette95's Avatar
Where was this connector...was it under the dash or do you mean the actual connector on the unit in the tank?
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 02-08-2020   #10
Flyman 27
Flyman 27's Avatar
It was the conn at the sender unit. It looked fine, but there were corrosion issues inside the connector.
Cams by Pete
