Old 07-02-2013   #1
Schrade
Default Window problem; anyone beeh here? [snappic]
Snappic shows it all here men; anyone know right off hand here where I need to go with it?
(it squares up right away, when it starts 'up', and goes down square as well, when it goes 'down')
Old 07-02-2013   #2
USAFPILOT
USAFPILOT's Avatar
Default Re: Window problem; anyone beeh here? [snappic]
could be the plastic guide that attatched to the front of the windshield at the bottom of the glass. Does the window rock back and then strike the B pillar when you open and close the door?
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI.
Old 07-02-2013   #3
Schrade
It does not rock at all...
No leaks; it's tight when 'up'...
Old 07-02-2013   #4
USAFPILOT
USAFPILOT's Avatar
that window guide is really the only thing it can be. You can loosen the three adjustment bolts and maneuver the window whichever direction you want it to go, but that window guide is needed to keep it straight. Shine a flashlight down inside the door and try to see if the guide is there. It is a two pronged plastic fork with felt in the middle that runs up and down a vertical post near the front of the windshield.
Are you proficient at removing the door panel?
Old 07-02-2013   #5
USAFPILOT
USAFPILOT's Avatar
That window guide is cheap plastic, and one of things that will fail eventually, if it hasn't already. I think its your best bet.
Old 07-03-2013   #6
if it goes up square and is tight, is there something in the door keeping it from staying square when going down?
I replaced both of my regulators in my ZR-1.. one was loose and I felt if I had to spend time getting them aligned might as well be with new hardware
Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback
Old 07-03-2013   #7
USAFPILOT
USAFPILOT's Avatar
the plastic thing I keep mentioning crumbled on mine and the window would crunch it at the bottom when I rolled it down. This one could be doing something similar if there is debris in the bottom of the door.
Old 07-03-2013   #8
mike100
One of my inner window seals is kind of bendy also... seems to just be age related.
