Old 04-20-2012   #1
Jim Nolan
Default SES light
I had my '92 modded a couple of years ago by a known tuner but I wasn't real happy with some of the results, (rough idle and backfire) so I had Haibeck retune an extra e-prom I had for me to see if I got different results. The mods were;
Ported heads, injector housings and plenum
SW headers no cats
Corsa exaust
3:92 gears
Reset cams
and I added
K& N filter
Relocated temp sensor
The Idle is smooth and the backfire is gone but with a hard shift above 6k I get a momentary SES light. Using Gordan's kit I could not find any stored codes, Marc set fuel scheduling for 410/420hp. Any ideas?
Old 04-20-2012   #2
Default Re: SES light
vac leak
Old 04-20-2012   #3
It could be you are running out of vacuum and it's setting a DTC 61 intermittently ?? You said hard run to 6+k rpms, and that would be where the manifold vac drops almost to zero and in theory our vacuum pump is supposed to pick up any shortage of vacuum in the system to keep the 2* actuators pulling on the 2* linkage.
Not to be a wise guy, did you use the Gordon jumper for the CCM? I think that's where the history codes and intermittent codes are stored....I think!
Old 04-20-2012   #4
Jim Nolan
I tried them all, ECM, CCM etc; nothing. If it is a vacuum leak I wonder why it didn't show up with the other e-prom? But, I'll check all the vacuum lines.
Old 04-20-2012   #5
My guess would be a lazy secondary vaccumm actuator under the plenum. One of the pair
Old 04-20-2012   #6
Could be running a bit lean at top end depending on what Marc did with fuel. See if you can datalog while you do a run.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 04-24-2012   #7
Ummm-yeah. Had that thought too when I read 410-420. Mine was initially set by Marc for ≈ 450 hp before I ported the heads. I had no SES. Logically speaking, it would seem (to me too) that one possiblilty might be a lean condition???
Dom, we're starting to think alike...AND DON'T THINK I'M NOT WORRIED!!
p.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 04-24-2012   #8
p.
Well if the SES light comes on then then goes off during hard acceleration, that usually indicates an intermittent lean condition. Now WHY its lean is a matter for discovery. I had that happen when I ported my top end. Turned out to be fuel pump.
