View Poll Results: Did you eliminate your Secondary Throttle Vacuum System? | |||
Yes. | 21 | 55.26% | |
No. | 17 | 44.74% | |
Voters: 38. You may not vote on this poll |
11-21-2017 | #31 |
Re: Did you eliminate your Secondary Throttle Vacuum System?
There are a few variations. You can leave the parts in place, but just make them non-functional (so the throttle plates do not close). Or you can remove everything related to the secondaries (including the throttle plates). Or something in between.
11-21-2017 | #32 | |
H
11-21-2017 | #33 | |
I highly recommend one FIRST PLUGS THE RUNNERS with a wad of paper toweling to prevent dropping a screw down inside the head. THAT could mean removing having to pull the motor and the head should the valve be open (my luck!) and the screw couldn't be retrieved with a magnet or the like. Then the shaft and the bearing can be removed together, and (I used) a Dorman freeze plug and JB Weld to seal the hole left by the bearing/shaft. To extract the shaft and bearing, once the actuator and linkage was removed, I used a 1/2" long (3/4" ID, IIRC) piece of metal conduit tubing placed over the bearing and placed a fender washer over the top (capping the conduit piece) so the threaded end of the shaft protrudes. The little nut from the actuator linkage arm(s) is then reinstalled and screwed down onto the fender washer. Continue screwing it down against the washer, thus extracting the shaft and the bearing together. Voila! I'll have to look up the Dorman plug #; a metric size approx 3/4" in dia., but per Pete's recommendation I smeared a little JB Weld on the edges of the Dorman plug. Then placing the Dorman over a 3/8" socket on the end of a short extension, a hammer was used to drive the Dorman into the void left by the bearing and sealing the hole securely. Put the air box cover back on... Done w/ all that secondary BS (with the addition of Marc's delete chip and removal of the vacuum line to the SPT MAP switch).
11-21-2017 | #34 | |
Correctamundo
11-21-2017 | #35 | |
I'll just fix it, it doesn't seem to be much complicated. |
11-21-2017 | #36 |
I should read more before responding🤤
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 11-21-2017 at 04:46 PM. |
11-21-2017 | #37 | |
Sounds like your next article for HOTB! Can’t wait... H
12-06-2017 | #38 | |
Sent from my SM-G955U using ZR-1 Net Registry mobile app
[B][I][COLOR=red]1990 ZR1[/COLOR][COLOR=black] [U]#00077 [COLOR=red]RED[/COLOR]/[COLOR=red]RED[/COLOR] (10Y022 PEP CAR) [/U][/COLOR][/I][/B][B][I][COLOR=red]1991 ZR1[/COLOR][COLOR=black] [U]#00517 ("Irene")[COLOR=red]WHITE[/COLOR]/[COLOR=red]RED-SOLD:cry:[/COLOR] [B][/B] [/U][/COLOR][/I][/B][B][I][COLOR=red]1992 ZR1[/COLOR][COLOR=black] [U]#00445("The Revenant")[COLOR=red][COLOR="Black"]BLACK [/COLOR][/COLOR]/[COLOR=red]RED(2016 T.O.D!) [/COLOR] [/U][/COLOR][/I][/B] [B][I][COLOR=red]2009 [COLOR=red]Z06!![COLOR=black]BLK/BLK rare Linen interior[/COLOR] 707HP!![/COLOR] [/COLOR][/I][/B] [B][I][COLOR=red]2006[/COLOR] BLK/BLK Z51 (Just SICK FAST!)SOLD)[/I][/B] [B][I]1996 BLK/BLK LT4 Grnsprt(sold...Twice!)[/I][/B] [B][I]1991 RED/REDL98(Fell off the shipping truck:([/I][/B] [B][I]1980 BLK/RED L82(Sold)[/I][/B] [B][I][B][I]1990[/I][/B] RED/BLK(sold.....In Japan)[/I][/B] [I][COLOR=black][B][I]2006[/I][/B][/COLOR][/I] [COLOR=red]Mustang GT[/COLOR] ([B][I]mach 1[/I][/B])[B](sold)[/B] [COLOR=black][B][I]1969[/I][/B][/COLOR] [COLOR=red]Mach[/COLOR] [B][I]1(sold in Japan)[/I][/B] [COLOR=black][B][I]1969[/I][/B][/COLOR] [COLOR=red]Mach[/COLOR] [B][I]1#2(sold)[/I][/B] [B][I]WAZOO Member...[/I][/B] [url]www.evolution-motorsport.com[/url] facebook/evolutionmotorsportengineering Your Local [url]www.Amsoil.com[/url] dealer/user.. *Victory Loves Preparation* |
12-07-2017 | #39 |
08-02-2018 | #40 |
so true! the LSV popped one of those little suckers out last year after 20k plus miles of no secondaries we were running at the track and the huge vacuum leak made for an interesting trip home
