01-23-2018 | #11 |
Re: Wheel help guidance please
I would do what GC is doing. Find some real ZR-1 36mm offsets AFS or GM.
They could even have some blemishes. Then powder coat them black with a polished lip. Sent from my iPhone using ZR-1 Net Registry
Dennis Fierstein 90 ZR-1 #2562 Atomic-Z ZR-1 Net Registry Chairman of the Board ZR-1 Net Registry Treasurer |
01-23-2018 | #12 |
I made the call--- no longer available with no idea when (if) they will be made again.
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker |
01-23-2018 | #13 | |
The hunt continues!
01-25-2018 | #14 |
Another recommendation here to buy and powder coat an OEM set. You'll pay a little more upfront, but I think that you'll end up with a higher quality, and lighter, wheel that fits correctly without the use of spacers - and unless the supply of 17" tires dries up, you'll always be able to resale easier than an aftermarket set.
Scott
WAZOO Member '95 Callaway SNAT 450 Aerobody Coupe - Black/Black '92 Callaway SNAT 400 Convertible - Polo Green/Beige '91 ZR-1 #1231 - Arctic White/Saddle (SOLD) '90 ZR-1 #2547 - Turquoise Metallic/Black '89 Callaway Twin Turbo Aerobody Coupe #027 - Black/Black '85 Corvette 454 Coupe - White/Red |
01-25-2018 | #15 |
http://www.westcoastcorvette.com/p-5...hined-lip.aspx
Had you contacted these folks? If anyone has, or can get them, WCC can. Good Luck! Marty |
01-26-2018 | #16 |
Another vote to invest in an OEM set. They fit, look and function great, and would retain their value if you ever want to change back.
Spray painting with a removable rubberized, but durable, coating of black Plasti-dip might be another option. There are many options on their web site, along with video demos. One video https://www.youtube.com/watch?time_c...&v=AFYX_5cS1go Many wheel kits at their site: https://www.dipyourcar.com/collectio...lar-wheel-kits A good friend coated his silver '83 Porsche 911 wheels with it. Was very pleased, except he said he'd have done a little better prep work (see video). All the best in your search.
'94 ZR1 LT5 - Dark Red Metallic '79 L82 4-speeds of fun '96 LT1 Borla, H-pipe, TB, CAI (Sold) "An adventure is only an inconvenience rightly considered. An inconvenience is only an adventure wrongly considered." -- G.K. Chesterton |
01-26-2018 | #17 |
Factoryreproductions.com has the correct offset for $189ea
https://factoryreproductions.com/sho...-corvette-zr1/
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
01-26-2018 | #18 |
The problem with 'all' after-market now is that the deeper pocket on the rears is done by 'no one' - I'm quite sure. I haven't seen the deep pockets for quite some time. I have one set of FactoryReproductions with deep pockets @ 50mm, a set of someones with the larger machined lip I think with 50mm and deep pockets but nearly everything I've seen recently has a pocket that matches the fronts.
A ZR-1 with 11's on the rear without the 'deep pocket' just looks odd. |
01-27-2018 | #19 |
01-27-2018 | #20 | |
Sent from my LG-TP260 using ZR-1 Net Registry mobile app |
