09-02-2015 | #1 |
Hurst Shifter Difficult 3rd
Hi All,
I've been enjoying my ZR-1 as much as the fair weather allows, and digging into a ton of these forum posts. Awesome. I've found that while driving (and parked with the engine off) selecting 3rd gear can hang up a bit in the shifter. I have a Hurst that the PO installed. Has anyone had a similar issue? Just changed the trans fluid tonight (haven't driven yet but still same engine off feeling), clutch level seems OK, and I've done the ZFDoc clutch hydraulics test (coasting down once at temp and pushing the clutch in, waiting 2 sec, and then selecting 1st and reverse), and everything seems smooth there. I might have some time in the next few days to dig into the console and inspect the shifter from above. Anything I should keep an eye out for? Thanks! Kelby UPDATE: Just drove it. Seems to hang up only sometimes. Played with it idling in the driveway a bit, seems smooth most times, then seems to bind up and not fully achieve 3rd (sometimes 2nd and 4th as well). Starting to think it's just not lining up right sometimes, maybe needs rebuilt? Tough to say as I don't know much about the mechanics of this shifter. Overall shift quality was improved by changing the trans oil though so that's good! Last edited by KPW; 09-02-2015 at 08:41 PM. Reason: UPDATE |
09-02-2015 | #2 | |
Re: Hurst Shifter Difficult 3rd
09-02-2015 | #3 |
Haven't changed the clutch fluid...what's the consensus on the easiest way for that? I have a fresh can of DOT4.
09-02-2015 | #4 |
Thank you for posting, same issue here.
Happens randomly shifting out of second, like it's getting hung up on something. Happened once coming out of first, made a loud "pop bang". There is no gear grinding whatsoever, and this happens during hard running & sunday driving. About a dozen occurrences in 200miles. Hurst Shifter, aftermarket grip (that I like) Fidanza flywheel, oem slave cylinder I'm a confident shifter, sometimes upshifting without the clutch. Also recently relearned to not "ride the clutch" which was a bad habit I didn't realize was detrimental to internal parts.
1990 ZR-1 #1587 1990 ZR-1 #1727 |
09-02-2015 | #5 |
I have used this method from Ranger for several years with real effectiveness.
http://youtu.be/gBbsy0LjUvE
09-03-2015 | #6 | |
Awesome post up Dom thanks for sharing. I now have a weekend job
09-03-2015 | #7 |
Flushed a whole can through the system with Ranger's method. Still a little dirty so I'll continue with that periodically to try and clean it up good.
Did some more investigation with the shifter hang up issue...seems to happen even without the clutch (engine off) which still seems to point to the shifter? Strange to me is the intermittent nature of this issue. |
09-03-2015 | #8 |
Just tossing out a question ...
Are you sure it's the shifter and not the trans? Perhaps we can ask if anyone has had this issue with the stock shifter. If not, then you're probably right. There's a rubber boot underneath the car. I suppose you could shoot some lithium grease in there, but it's a pain to work with. Therefore, I'd think it'd be easier to go in from the top to apply some new grease, and, if you're lucky, maybe recreate the issue while you're looking at the shifter workings. Good luck. |
09-04-2015 | #9 | |
I can say that with the engine off and running through the gears with my stock shifter, it will often randomly refuse to go into a gear - not always the same one tho. That isn't unusual, considering how synchros work and depend on movement to align the splines. While driving/racing, it hasn't been a problem, except occasionally for 5th gear - a synchro(?), I suspect. But, in comparison, I've not had any issues at all with shifting Ami's 91 Z; at least while driving (never tired it with the engine OFF). However, after seeing that video, I may step up my clutch maintenance some...but I doubt it will be with every gasoline fill-up per the video. (That seems a little "OC" to me.)
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 09-04-2015 at 07:55 AM. |
09-04-2015 | #10 | |
