Old 04-27-2014   #1
LantanaTX
Default R134 A/C conversion
Does anyone know where the orifice is? I realize I can just put the R134 in but changing the orifice to a variable results in colder air. Usually there is some dimpling in one of the pipes near a union which holds the orifice but I am not finding it on this car.
[SIGPIC][/SIGPIC]1991 #0663
LantanaTX is offline   Reply With Quote
Old 04-27-2014   #2
WVZR-1
Default Re: R134 A/C conversion
Drops in the evaporator tube.
Old 04-27-2014   #3
LantanaTX
Great thank you!
Old 04-27-2014   #4
WVZR-1
Great thank you!
You should see the crimp in the tube. Those connections can be difficult to unthread.
The crimp can be seen here:
http://www.ebay.com/itm/AC-Evaporato...d0ba3b&vxp=mtr
Old 04-27-2014   #5
Schrade
I converted an '87 to 134 without changing any hardware, except an adapter fitting, that I remember.
I did do the conversion flush a couple extra times, and vented it ( just to see how much was left, of course ), and had no problems thereafter.
Old 04-27-2014   #6
LantanaTX
I did the same the first time I converted one, but it never got quite as cold and then I learned about changing the orifice and then freezing cold.
Old 04-27-2014   #7
LantanaTX
Thank you, I must have missed it. Just couldn't see the crimp. They are usually at the evaporator or the filter dryer.
Old 04-28-2014   #8
scottfab
scottfab's Avatar
chances are you're going to introduce some moisture to the system when you put the new orifice in I would suggest changing the dryer while you're in there. they are surprisingly cheap
Scott
Old 04-28-2014   #9
LantanaTX
Never had to replace a dryer before when doing this, but the system must be evacuated before charging.
Old 04-28-2014   #10
Its always recommended to change out the receiver driver before doing the conversion. Your going to have to recharge the system anyway.
