04-01-2014 | #21 | |
Re: INFL RST light came on today in the rain , seat belt light too ---
The steering wheel, SIR bag, is well documented and I imagine that when there were deployments and service required they were dealt with on a one on one situation. I've never actually looked for documentation so it could be out there. The '90 sensors are equal length and the harness from the DERM to each location was a correct length. 10177901 is a '91+ part number with DELPHI terminals for the LH side and is noted as a Forward Discriminating Sensor, a 10177902 is for the RH side and is noted as the Forward Arming Sensor. The '90 part number is 10094613 and is for of course a quantity of 2. The '90 TSB for corrosion and service is here: http://zr1.net/forum/showpost.php?p=157442&postcount=4 Last edited by WVZR-1; 04-01-2014 at 03:32 PM. |
04-01-2014 | #22 |
Even thought links to a pictorial on repairing the SIR (INFL REST) issue are broke for now. Here is one pic from that procedure.
It show the surface prep around the sensor. Buying new sensors should not be necessary. The rain you were in aggravated the corrosion issue. A quick test of this theory is to back out the mounting bolts a turn or two the re-tighten. Then clear the code and test. This is NOT a permanent solution however. The permanent solution is to clean and prep the surface and use dielectric grease on reassembly.
04-01-2014 | #23 |
You guys are great, thanks for the links / part numbers / and information!
I appreciate it and feel a lot better about attempting to fix the situation now! ---
[SIGPIC][/SIGPIC] 01' Dodge Viper GTS 11' Ford Raptor 90' ZR-1 Corvette LPE #699 |
04-01-2014 | #24 |
04-01-2014 | #25 |
I'm pretty sure its the drivers side , since I am getting the "seat belt" light too.
I went to install a battery a month ago and there was water puddled up around the frame ... so I can see why this is a problem on our cars. I may as well try my Tech 1a for the first time too , I haven't tried it yet. HAHA! I always stub my toes doing things the first time ---
