Old 10-14-2014   #11
Franke
Default Re: Important news on LT5 fuel injectors
I have them in my 90 for better than 2 years and no problems at all. Thanks FIC.
Old 10-14-2014   #12
Blue Flame Restorations
FIC, thank you for being there for the Brotherhood!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 10-22-2014   #13
Agpilot1
Going to jump on this deal right now! Thank you FIC!
Shea
'90 #2815----SOLD
Agpilot1 is offline   Reply With Quote
Old 10-22-2014   #14
JimZRyd
JimZRyd's Avatar
Originally Posted by Kevin View Post
Put a set of your new SS ones in a few years ago and love them. Shipping was fast and the product is great.
Do old orders qualify for the warranty or no?
I'm with Kevin...Put in a new set earlier this year. Would it be included in your warranty ?
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
JimZRyd is offline   Reply With Quote
Old 01-19-2015   #15
I am assuming these injectors are Ford #19 lb injectors as Brad suggested?
I am also assuming resistance check is around 14 ohms?
What horsepower are they good for in the LT5?
Just guessing here.......
I am assuming the Ford #19 are 19 lb injectors rated at a fuel pressure of 39.15 psi.....read that somewhere
If we assume brake specific fuel consumption (bsfc) of .5 lbs of fuel per hour per horsepower.....
Lets assume 400 hp.....and 80% duty cycle and 16 injectors
We would get 15.625 lbs per hr for each injector is required.
If we upped the fuel pressure to 45 psi...we would get a bit over 20 lb per injector available for the Ford #19s which is plenty given the 15 lbs required for 400 hp..... Is this correct?
See Restoration of the Injectors
Old 01-19-2015   #16
My question is "Do you provide the Injector Offset based on BATT voltage? Is it the same as stock (which I doubt)?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
