Old 07-10-2014   #1
MickeyD
Default Fuse Help
My cigarette lighter, visor lights, (new visors) and storage bin lights all out. Can anyone tell me which fuse or fuses that is. And where is the fuse for hood lights so I can pull fuse.
Thanks guys
1990 ZR1 Red/Black #2469
1990 ZR1 Black/Black #843
1993 ZR1 Ruby 40th Anniversary #112
MickeyD is offline   Reply With Quote
Old 07-10-2014   #2
MickeyD
Default Re: Fuse Help
Yep. It is on an auxiliary fuse block located under the passenger side hush panel.
You'll have to remove the hush panel (no biggie), and find the fuse block pretty close to the center of the area covered by the panel. I forget what it is marked as off hand (I should tho, cuz I just recently replaced my fuse for those circuits you mentioned).
P.
Thanks Paul but you are talking to a non-mechanic idiot. Lol. What is a hush panel and exactly where is it?
Thanks
Old 07-11-2014   #3
RICHARD TILL
Its the carpeted area between the passenger`s feet and the glove box.
Old 07-12-2014   #4
WVZR-1
Thanks guys
What year car are you working on? You've several in your SIG!
If it's a '90 the "CTSY" fuse is NOT in the AUX panel under the hush panel. I believe it should be top left, first in the main fuse panel. I doubt that any year CTSY fuse would be in an AUX panel. That makes "no sense".
AUX panel has only CRANK-A/B, PWR DOOR, THEFT and FP2.
Hood lights are also on CTSY
I assume you know where the main fuse receptacle is but if not, open right door and it's on the exposed end of the instrument/dash panel.
Old 07-12-2014   #5
Might wanna check your reference source, cuz I promise you on a '90 the fuse that powers the lighter, the map light on the mirror and the door locks IS on the aux box under the hush panel. Ask me how I know...
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 07-12-2014   #6
WVZR-1
I don't find anything in the '90 FSM that contradicts what I mentioned. I'm not aware of any revisions so I'm left I guess with the ... "asking how you know"!
I noticed another post by the OP and I believe he may have issues with the "CRUISE" fuse but of course I don't "KNOW"! He mentions replacing some parts and I'm not really sure which. In this thread he mentioned wanting to disable the hood lamps so I believe the "CTSY" fuse should have been good so his problems mentioned in the other are likely NOT related to a fuse problem and he seems to confirm the fuse is good and actually I believe mentioned he "replaced".
Old 07-12-2014   #7
Franke
Not sure we talking the same circuits here as Paul indicates the mirror lights, door locks and lighter in aux panel and what was mentioned in the post is the cigar lighter, visor lamps, under hood lights and glove box.The CTSY fuse powers some of those as WVZR1 indicates but not all and is in the main fuse panel. Maybe i'm not following this thread right.
Old 07-12-2014   #8
Conflicting info - as to what circuits are distributed among the AUX block and the (CTSY) on the main block. I'll make a physical verification, soon as the rain stops and get back.
P.
90 #1202
Sans secondaries
Old 07-12-2014   #9
WVZR-1
If we're indeed speaking of a '90 fuse blocks and what's powered, 8A11-6 for the vanity and lighted rearview mirror (CRUISE FUSE), 8A11-3 for the cigar lighter, glove box, hood and misc. courtesy (CTSY FUSE) 8A11-12 for AUX BOX,
The complete courtesy and cigar lighter 8A114-0, 1, 2 & 3.
Old 07-12-2014   #10
I didnt know there were lights for the storage bins.
