Go Back   ZR-1 Net Registry Forums > Corvette > Corvette Technical Questions
Old 03-20-2016   #1
KJL
Default How deep to install pilot bearing?
My plan was to measure existing but the bronze bushing sspun in the bore and just fell out. Soooo, I see probably where it goes as the inner bore in the crank is stepped. Thought I would double check. I have the FSM but don't believe it is called out there. Thanks!
Update: 10-5-2016: Drive it in until it hits the shoulder. That puts it at about where Racinfan83 states below.
1995 ZR1 #159
Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp
1992 ZR1 #280
Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp
1996 Collectors LT4 (Stock)
1972 Convertible 434 Small Block
572 rwhp
KJL is offline   Reply With Quote
Old 04-20-2016   #2
Racinfan83
Default Re: How deep to install pilot bearing?
14.5 mm +/- .5 mm Mine went in to 14.9 and seemed to stop there.
