10-07-2014 | #11 |
Re: Intermittent issue starting the car , VATS or starter problem? ---
Agreed Paul. When I first got my current ZR, I experienced same thing. I made a jumper and bypassed the clutch switch. I continue to depress the pedal just as a precaution and ALWAYS make sure the shifter is in neutral.
But yeah there are times when it's convenient to be able to reach thru the window and just start the motor. One reason I made sure I had an eBrake w the C6Z rear calipers.
10-07-2014 | #12 |
Bypass it and dont look back.
10-07-2014 | #13 | |
Which way you look depends on if the Transmission is in Reverse or Forward gears when you start the LT5 without clutch depressed
Starting the engine in gear is always a chance and with you outside starting the LT5 through the window......well..... Quote:
Starter Relay, Wiring Harness, and Plugs Tricks
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-07-2014 at 11:20 AM. |
10-07-2014 | #14 | |
10-07-2014 | #15 | |
But I have never had to use my Tow Bar since reconditioning the Starter and adding the Starter Relay See Item, #2 Lifting and Towing the ZR-1
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-07-2014 at 11:44 AM. |
