09-22-2017 | #21 |
Re: Oil Change
Mobile 1 10W-30
https://www.mobil.com/english-us/pas...xmobil-1-10w30 Sent from my iPhone using ZR-1 Net Registry
09-23-2017 | #22 |
Re: Oil Change
Amsoil and Bosch filter. Replace filter before I start the car. Warm up car,get car in the air and drain oil. Half hour later cars on the ground and fill with oil. What little oil left in the engine before refill is fine. Just noticed this post is 4 years old.
09-23-2017 | #23 |
Re: Oil Change
So know one has changed there oil in 4 years lol ?
Sent from my LG-H831 using ZR-1 Net Registry mobile app |
09-23-2017 | #24 |
Re: Oil Change
09-23-2017 | #25 |
Re: Oil Change
Brad Penn 10w30 with Mobil 1 extended life filter, once per year in spring.
Marty |
10-06-2017 | #26 |
Re: Oil Change
10-07-2017 | #27 |
Re: Oil Change
The high mileage has some type of modifier that helps stop gasket leaks think that's the only difference.
Sent from my XT1585 using ZR-1 Net Registry mobile app |
10-07-2017 | #28 |
Re: Oil Change
Those jacks make changing the oil a lot easier. I built two wooden ramps that ar idiot proof and won’t slide. Changed mine yesterday with Monle 1 10W-30 and a PF930C Delco oil filter.
10-07-2017 | #29 |
Re: Oil Change
Monle 1?
10-07-2017 | #30 | |
Re: Oil Change
Just using "Mobil-1" w/o further distinction is like saying oil is oil w/o consideration of ZDDP, or gas is gas - w/o any consideration for octane levels. Yeah, the Z will run on 87 octane - the knock sensors and the ECM will back off the timing several degrees, performance will consequently suffer some, but yeah, it will run on it: has to to comply w/ EPA standards (dating back to the mid/late 80s). Not quite the same analogy tho with oil. Loss of performance due to octane reduction is (more or less) immediately noticed. But, with oil, wear is the issue, and damage (due to inadequate levels of phosphorous/zinc ZDDP levels) is insidious . In time (wear) will reach a critical point and catastrophic failure is a real possibility. Oil manufactures go on and on about this and that, and how the lower levels of phosphorous/zinc is offset by (you name it). I occurs to me they're often protecting their butts; admitting nothing and playing the odds. But, LOOK their oils recommended, focusing on the ZDDP levels in particular, as it applies to their racing and flat tappet motor applications! You don't have to be a "rocket scientist" to "look beyond..." As w/ most things, too much (of a good thing) or too little (ZDDP) apparently has their drawbacks. I ain't no chemist; more of a statistician (I guess), and the "bell curve" seems to favor ZDDP levels in the 1200/1300 ppm (phosphorous/zinc) for our general application as well as that of other flat tappet motors. So, I guess what I'm trying to say is, (most) wouldn't gas up their tank with any ol octane, and likewise neither should one fill the crankcase with any ol oil (Mobil-1 or whatever) w/o availing themselves of the specs of the different products they offer and for what application it is best suited. Oil isn't just oil. This chart from Mobil-1 has over a dozen different products with ZDDP levels running from low to very high. It's probably prudent to know there is a difference? See Marc Haibecks article on "Modern Oils..." .
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 10-07-2017 at 11:49 AM. |
