10-04-2013 | #51 |
Re: Front fascia yank and clean...
Oh yeah. Looks like it (Canister assembly) was lowered or modified to allow the light fixture to fit in. correct?
10-04-2013 | #52 | |
When I was bolting down the EVAP cannister Torx bolt to the crash bar, yesterday, I couldn't get at it - blocked by the cannister.
I don't remember the block @ dis-assembly... Then I looked at my reference snappics: Quote:
And that's when I saw the missing bolt too...
10-04-2013 | #53 |
Now I know why that bolt was missing.
Originally, the BRACKET was rotated counter-clockwise, WITH the cannister loose in the bracket clamp, and DOWN, catty-wampus, OUT OF THE WAY OF THE SIDE MARKER LENS. The missing EVAP bracket LOWER bolt was missing on purpose.
10-04-2013 | #54 |
So how to get the side marker lens in place?
By getting the EVAP bracket lower bolt out. Simple. Remove the fascia; unscrew the bolt.
10-04-2013 | #55 | |
Thanks again there to Steve too - his diagrams showed SOMEthing was wrong - I just didn't see it at the time... Plenum pull has GOTTA' be easier than this...
10-05-2013 | #56 |
Great job sorting out the mess you found while doing some cleanup. Your luck looks like mine jump into what appears to be a straight forward job than try and dig your way back out.
10-07-2013 | #57 |
You need to start up Jeff's Psychic Hotline (for 'entertainment purposes only', of course), cause you called this one...
................................... "It ain't over til the fat lady sings..." Not only is the fat lady NOT singing; neither is my driver's side HORN! It already sounds wimpy with STEREO horns, but now it's Mono. Good thing tho' that it's driver's side horn that's out, cause I know Sign Language, if someone pulls out in front of me: (maybe I can get George to ride shotgun) http://www.youtube.com/watch?feature...&v=D0IJkD0znCQ Anyway here, horn won't fit after rotating the EVAP cannister, to stop binding on the side marker lens body. Talk about the 'horns of a dilemma'!!! So it's time for some more fab / hack work. About 3/8" out of the horn mounting arm, then re-weld, will get me all the clearance needed here. I thought about mounting above the headlight controller module, but flipping the headlights and hearing a gouging sound isn't too appealing. Even had to re-route one of the EVAP can purge solenoid tubes, around in FRONT of the cannister, back to the vac source, but still no go. to be continued...
10-07-2013 | #58 |
What a PITA. This info is valuable for anyone wanting to change out front bumper/fascia/lighting from a different year so that they can see all of the engineering needed to make it work.
Just thinkin' is there room on the other side headlight bucket for the horn? |
