06-26-2017 | #1 |
WTB - Plenum insulator plates
All,
I need to source a set of phenolic plenum spacers. Wish I'd bought Lee's last year for a good price. Anyway, I'm hoping to use these to correct a slight misalignment I'm having with the ports on my personal engine. Would rather grind on the phenolic to make a smooth transition between plenum & IH.
Todd ____________________________________ [SIGPIC][/SIGPIC] [email]pepmeierengines@yahoo.com[/email] [URL="http://toddpepmeier.wix.com/pepmeierengines"]visit our website[/URL] [URL="http://pepmeierenginedevelopment.blogspot.com/"]Blog[/URL] Friend us on Facebook too: [url="https://www.facebook.com/profile.php?id=100011443683384"] Pepmeier Engine Development[/url] Last edited by tpepmeie; 06-26-2017 at 12:22 PM. |
06-27-2017 | #2 |
Re: WTB - Plenum insulator plates
Todd,
I've been running a set for years - I purchased 1/4" phenolic sheet from NORVA Plastics when I lived close to them (they sell excess job material on eBay), and made my own using the gasket as a template. The material is very easy to work with and cut/shape/sand as needed. They are currently selling 1/4" sheets on eBay (G10). Good Luck! Regards, Mark
Mark Horner President, ZR-1 Net Registry 91 ZR-1 #2016 95 ZR-1 #21 DRM-600, LPE 385 |
06-27-2017 | #3 | |
06-27-2017 | #4 |
Not to Hijack a thread but what is the advantage or disadvantage to these spacers. I've never really got a straight answer from anyone. I have a set on my car that a previous owner had put on and I thought about removing them when I do my first plenum pull if they are not helping the performance of the car.
Steve,
_______________________ 1990 Bright Red/Black #946 B and B X-Pipe Stainless Works Long Tube Headers Cat delete 49th Street Rockers Haibeck Chip and Tune |
06-27-2017 | #5 |
Principal Advantage: Thermal insulator for plenum, to impede heat soak from the engine
Other Advantage: Marginal increase in air circulation under plenum, aids in cooling of plenum & DIS Module. Disadvantage: 1/4" spacers frequently result in intake contact with underside of hood. Disadvantage: Requires some bending of vacuum line to PCV top connector. Disadvantage: requires 2 sets of plenum gaskets. & longer bolts
06-27-2017 | #6 |
I know Todd needs them for another purpose, but the spacers introduce one more place for a vacuum leak.
06-28-2017 | #7 | |
^^^ what he said. I'm not doing this for any performance impact, and I doubt the claimed benefits of plenum insulation are even measureable! I just need the spacers to improve the transition interface between the housings and plenum. What happens, in my case, is a slight decking of the block, combined with skim cut on the cyl head deck, and a thinner MLS gasket = the heads sit fractionally lower. The plenum ports no longer line up perfectly with the housings, so I need to fix that. We're talking millimeters here. One added consequence, the extra 1/4" or so should move the natural tuned length of the intake slightly lower (perhaps 100 rpm). Peak torque on Build 1 was 5800 rpm, which is more or less where the factory HP peak was, and where the stock runner length is tuned.
Todd ____________________________________ [SIGPIC][/SIGPIC] [email]pepmeierengines@yahoo.com[/email] [URL="http://toddpepmeier.wix.com/pepmeierengines"]visit our website[/URL] [URL="http://pepmeierenginedevelopment.blogspot.com/"]Blog[/URL] Friend us on Facebook too: [url="https://www.facebook.com/profile.php?id=100011443683384"] Pepmeier Engine Development[/url] |
06-28-2017 | #8 |
Todd, I have a used set of 1/4" on an engine I acquired last year.
07-03-2017 | #9 |
Todd,
If you don't get the set from Jerry, I have a new set that I bought from Lee earlier this year. It sounds like you need it more than me. Aloha, Craig
