06-19-2012 | #1 |
Headlight gear box.
After getting my new tires put on, I took the ZR-1 out for the first time in 24 months. Had quite a few people stop and look at my car and comment how they had read about ZR-1's, but never saw a real one. Nice to see that there are still some people who can look at a C4 and recognize a major difference!
Later in the evening I left to go home and when I turned on the head lights, they rotated half way around a quit. I made me some new pucks out of Delrin and rebuilt them. Head lights work as new again. I thought it was quite odd that both sides failed at the same time. When I opened the gear box, both looked they had salt in them. I wonder if the lube that was applied originally causes the original pucks to desintigrate?? I also wonder what the OEM pucks were made of? |
06-19-2012 | #2 | |
Re: Headlight gear box.
06-19-2012 | #3 |
Gordan Killebrew advised me that because we all run glass headlights as opposed to the plastic ones Chevy put in them the gears are sure to fail.
06-19-2012 | #4 |
Gordon told me the same thing, but it is the bushings that turn to powder inside the headlight motor housing, yet the gears remain serviceable. My Z with 3,500 miles had bushings that were disintegrated, so the original question was what caused this to happen over time?
Bert Rankin 1991 ZR1 Steel Blue / Steel Blue #1029 Haibeck chip, slotted rotors, camber brace, C-beam plates, OBX exhaust, Nitto NT555 tires [SIGPIC][/SIGPIC] |
06-19-2012 | #5 |
The usual GM quality...
06-19-2012 | #6 |
Make sure and change the little screws that hold the motor on as well. On the 89 I had changed the bushings and then about a year later the screw head popped off and the motor tore up the brushes on the inside. This was about 4 years ago and since I don't drive it much I still haven't fixed it. It wouldn't have been an issue if I had changed them in the first place to SS or something else. Two screws per motor, you can see one in this picture next to the white and green wires:
Don't get cheap like I did or just think they will hold. Spend a few cents and be safe. The ones on the 89 looked no worse than the ones pictured above. Daniel |
